[postgis-tickets] r15386 - Use local RUNTESTFLAGS env variable (global doesn't seem to work)
Sandro Santilli strk at kbt.io
Wed May 3 22:07:46 PDT 2017
Author: strk
Date: 2017-05-03 22:07:46 -0700 (Wed, 03 May 2017)
New Revision: 15386
   trunk/.drone.yml
Modified: trunk/.drone.yml
--- trunk/.drone.yml	2017-05-03 22:32:09 UTC (rev 15385)
+++ trunk/.drone.yml	2017-05-04 05:07:46 UTC (rev 15386)
@@ -1,9 +1,5 @@
 # See http://readme.drone.io/0.5/usage/overview
-env:
-  global:
-    - RUNTESTFLAGS=-v
 # See https://git.osgeo.org/gogs/postgis/postgis-docker
 test-image: &test-image docker.kbt.io/postgis/build-test:trisquel
@@ -23,6 +19,6 @@
     image: *test-image
     commands:
       - service postgresql start
-      - make check
+      - make check RUNTESTFLAGS=-v
       - make install
       - utils/check_all_upgrades.sh 2.4.0dev
