[postgis-tickets] [PostGIS] #3749: ST_AsMVT support parsing keys/values from a jsonb column
PostGIS trac at osgeo.org
Wed May 3 23:59:28 PDT 2017
  Reporter:  Björn Harrtell  |      Owner:  Björn Harrtell
      Type:  enhancement     |     Status:  assigned
  Priority:  medium          |  Milestone:  PostGIS 2.4.0
 Component:  postgis         |    Version:  trunk
Resolution:                  |   Keywords:
Comment (by robe):
 I think it's the 9.3 issue.
 I see dronie is running:
 PostgreSQL version: PostgreSQL 9.3.13
 I suspect strk is running an antiquated version of PostgreSQL as well.
 I'm rerunning debbie and winnie.  They too were failing with 9.3 (with
 same error) but then they got an unrelated error which might just be an
 issue with simulatneous runs of other things or a memory leak crashing
 their postgres instance.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3749#comment:7>
