[postgis-tickets] r15388 - Set RUNTESTFLAGS env variable locally
Sandro Santilli strk at kbt.io
Thu May 4 11:01:55 PDT 2017
Author: strk
Date: 2017-05-04 11:01:55 -0700 (Thu, 04 May 2017)
New Revision: 15388
   branches/2.3/.drone.yml
global env doesn't seem to work with Drone
Modified: branches/2.3/.drone.yml
--- branches/2.3/.drone.yml	2017-05-04 17:15:16 UTC (rev 15387)
+++ branches/2.3/.drone.yml	2017-05-04 18:01:55 UTC (rev 15388)
@@ -1,9 +1,5 @@
 # See http://readme.drone.io/0.5/usage/overview
-env:
-  global:
-    - RUNTESTFLAGS=-v
 # See https://git.osgeo.org/gogs/postgis/postgis-docker
 test-image: &test-image docker.kbt.io/postgis/build-test:trisquel
@@ -22,6 +18,6 @@
     image: *test-image
     commands:
       - service postgresql start
-      - make check
+      - make check RUNTESTFLAGS=-v
       - make install
       - utils/check_all_upgrades.sh 2.4.0dev
