[postgis-tickets] [PostGIS] #3753: Gist penalty misbehaves if points are inserted in gridded ordered fashion
PostGIS trac at osgeo.org
Wed May 10 09:05:05 PDT 2017
 Reporter:  komzpa   |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.3.3
Component:  postgis  |    Version:  2.3.x
 Keywords:           |
 If data can be perceived as strips, gist penalty will always be zero,
 since leaves will be (width x height) = 0 x H = 0. For 2D data in ND index
 it will always be 0.
 There is patch by x4m for cubes that solves this problem by returning
 expansion of lesser dimension (length instead of volume etc.) with special
 mark:
 https://github.com/x4m/postgres_g/commit/76972490adb756e02df07f28723951f269729fcc
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3753>
