[postgis-tickets] [PostGIS] #3753: Gist penalty misbehaves if points are inserted in gridded ordered fashion
PostGIS trac at osgeo.org
Thu May 11 20:58:17 PDT 2017
  Reporter:  komzpa   |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by robe):
 PostGIS equivalent from Darafei Praliaskouski
 create extension if not exists postgis;
 begin transaction;
 SELECT setseed(.43);
 create table dataTable as select ST_MakePoint(x/1000,y/1000) c from
 generate_series(1,1e3,1)x, generate_series(1,1e3,1) y;
 \timing on
 create index idx on dataTable using gist(c);
 select q,(select count(*) from dataTable dt where dt.c && q) from (select
 ST_Expand(ST_MakePoint(x,y), 0.1) q from (select random() x, random() y
 from generate_series(1,1e4,1) s0) s1) s2 ;
 select pg_size_pretty(pg_relation_size('idx'));
 drop table datatable;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3753#comment:6>
