[postgis-tickets] [PostGIS] #3753: Gist penalty misbehaves if points are inserted in gridded ordered fashion
PostGIS trac at osgeo.org
Sun May 14 02:44:30 PDT 2017
  Reporter:  komzpa   |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by robe):
 Guess we should do the same for nd version to see if that is different:
 create extension if not exists postgis;
 begin transaction;
 SELECT setseed(.43);
 create table dataTable as select ST_MakePoint(x/1000,y/1000) c from
 generate_series(1,1e1,1)x, generate_series(1,1e1,1) y,
 generate_series(1,1e1,2) z;
 \timing on
 create index idx on dataTable using gist(c gist_geometry_ops_nd);
 select q,(select count(*) from dataTable dt where dt.c &&& q) from (select
 ST_Expand(ST_MakePoint(x,y,z), 0.1) q from (select random() x, random() y
 , random() z from generate_series(1,1e4,1) s0) s1) s2 ;
 select pg_size_pretty(pg_relation_size('idx'));
 drop table datatable;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3753#comment:8>
