[postgis-tickets] [PostGIS] #3754: Github mirror is broken
PostGIS trac at osgeo.org
Wed May 17 04:06:11 PDT 2017
  Reporter:  robe       |      Owner:  strk
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  Management 2.0
 Component:  buildbots  |    Version:  2.3.x
Resolution:  fixed      |   Keywords:
Changes (by strk):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 https://trac.osgeo.org/postgis/wiki/CodeMirrors should be back working.
 It's been a bloody adventure to setup the repository-sync-scripts, but now
 they should allow anyone to setup a local git-svn mechanism, and a
 mirrorer.
 Actually, it would not be bad if someone would want to try it :)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3754#comment:3>
