[postgis-tickets] [PostGIS] #3614: support PostgreSQL 10 and above numbering scheme
PostGIS trac at osgeo.org
Sat May 20 10:49:53 PDT 2017
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"15397" 15397]:
 #!CommitTicketReference repository="" revision="15397"
 Revise the PGVERSION numbering scheme so also works for PostgreSQL 10beta1
 and for all future PostgreSQL after 10
 Note previous patch put in did not consider the case of when 10.11 comes,
 that would end up ranking higher than 11.0 (110 vs. 1011).
 So we need to totally disregard the minor version for PostgreSQL  >= 10
 Closes #3614
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3614#comment:13>
