[postgis-tickets] [PostGIS] #3758: PostgreSQL 10 beta1 fails compile in gserialized_estimate
PostGIS trac at osgeo.org
Wed May 24 12:00:18 PDT 2017
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 The change in generate_series was deliberate: https://www.postgresql.org
 /message-id/2634.1495646891%40sss.pgh.pa.us
 I just fixed the regression test to use static data instead of dynamically
 generated in r15401
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3758#comment:6>
