[postgis-tickets] [PostGIS] #3759: PostgreSQL 10 failure on winnie both raster and geometry
PostGIS trac at osgeo.org
Thu May 25 13:04:36 PDT 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.4.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:  postgresql 10
Comment (by pramsey):
 That was a side change since sslot.numbers  is defined as *float4, it
 seemed like allocating space based on sizeof(float4) seemed like a smart
 thing to do, platformwise. Disappointing that it's causing a regression,
 though potentially it's an improvement? Have to check and see what result
 we actually like better.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3759#comment:4>
