[postgis-tickets] [PostGIS] #3760: raster blocksize check failing on PostgreSQL 10 _raster_constraint_info_blocksize is broken
PostGIS trac at osgeo.org
Thu May 25 15:14:58 PDT 2017
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 2.4.0
 Component:  raster   |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 Okay the release notes say this, so grudge-only I guess this is expected
 behavior change I can't complain about.
 This also prevents conditionals like CASE from controlling the execution
 of set-returning functions because set-returning functions are now
 executed earlier.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3760#comment:2>
