[postgis-tickets] r15403 - revert previous change to this file accidentally committed for #3761
Regina Obe lr at pcorp.us
Thu May 25 21:05:44 PDT 2017
Author: robe
Date: 2017-05-25 21:05:43 -0700 (Thu, 25 May 2017)
New Revision: 15403
   trunk/doc/extras_tigergeocoder.xml
But this is a work in progress for different item, not ready for commit.
Modified: trunk/doc/extras_tigergeocoder.xml
--- trunk/doc/extras_tigergeocoder.xml	2017-05-26 04:03:17 UTC (rev 15402)
+++ trunk/doc/extras_tigergeocoder.xml	2017-05-26 04:05:43 UTC (rev 15403)
@@ -966,13 +966,6 @@
           <listitem>
             <para><varname>parsed</varname> boolean - denotes if addess was formed from normalize process. The normalize_address function sets this to true before returning the address.</para>
           </listitem>
-          <listitem>
-            <para><varname>zip4</varname> last 4 digits of a 9 digit zip code. Availability: PostGIS 2.4.0.</para>
-          </listitem>
-          <listitem>
-            <para><varname>address_alphanumeric</varname> Full street number even if it has alpha characters like 17R. Parsing of this is better using <xref linkend="Pagc_Normalize_Address" /> function.  Availability: PostGIS 2.4.0.</para>
-          </listitem>
         </orderedlist>
       </refsection>
@@ -1006,7 +999,7 @@
       </refsection>
     </refentry>
-    <refentry id="Pagc_Normalize_Address">
+        <refentry id="Pagc_Normalize_Address">
       <refnamediv>
         <refname>Pagc_Normalize_Address</refname>
@@ -1070,12 +1063,6 @@
           <listitem>
           </listitem>
-          <listitem>
-            <para><varname>zip4</varname> last 4 digits of a 9 digit zip code. Availability PostGIS 2.4.0.</para>
-          </listitem>
-          <listitem>
-            <para><varname>address_alphanumeric</varname> Full street number even if it has alpha characters like 17R or 12 1/2.  Availability PostGIS 2.4.0.</para>
-          </listitem>
         </orderedlist>
       </refsection>
