[postgis-tickets] [PostGIS] #3764: PostGIS topology failures on PostgreSQL 10
PostGIS trac at osgeo.org
Thu May 25 23:27:49 PDT 2017
 Reporter:  robe      |      Owner:  robe
     Type:  defect    |     Status:  assigned
 Priority:  blocker   |  Milestone:  PostGIS 2.4.0
Component:  topology  |    Version:  trunk
 Keywords:            |
 After I was done fixing all the raster issues with PostgreSQL 10, surprise
 surprise.  topology has issues too.
 Creating database 'postgis_reg'
 Loading PostGIS into 'postgis_reg'
 Loading Topology into 'postgis_reg'
 PostgreSQL 10beta1 on x86_64-w64-mingw32, compiled by gcc.exe
 (x86_64-win32-seh-rev4, Built by MinGW-W64 project) 4.9.2, 64-bit
   Postgis 2.4.0dev - r15404 - 2017-05-26 06:16:27
   scripts 2.4.0dev r15404
   GEOS: 3.7.0dev-CAPI-1.11.0 8fe2ce6
   PROJ: Rel. 4.9.1, 04 March 2015
 Running tests
  regress/legacy_validate .. ok
  regress/legacy_predicate .. ok
  regress/legacy_invalid .. ok
  regress/sqlmm .. ok
  regress/legacy_query .. ok
  regress/addnode .. ok
  regress/addedge .. ok
  regress/addface .. ok
  regress/addface2.5d .. ok
  regress/addtopogeometrycolumn .. ok
  regress/polygonize .. ok
  regress/st_addisoedge .. ok
  regress/st_addisonode .. ok
  regress/st_addedgemodface .. ok
  regress/st_addedgenewfaces .. ok
  regress/st_changeedgegeom .. ok
  regress/st_createtopogeo .. ok
  regress/st_getfacegeometry .. ok
  regress/st_getfaceedges .. ok
  regress/st_modedgeheal .. ok
  regress/st_modedgesplit .. ok
  regress/st_newedgeheal .. ok
  regress/st_newedgessplit .. ok
  regress/st_remedgenewface .. ok
  regress/st_remedgemodface .. ok
  regress/st_simplify .. failed (diff expected obtained:
 /projects/postgis/tmp/2.4_pg10w64/test_26_diff)
  regress/topoelement .. ok
  regress/topoelementarray_agg .. ok
  regress/topogeo_addlinestring .. ok
  regress/topogeo_addpoint .. ok
  regress/topogeo_addpolygon .. ok
  regress/topogeom_edit .. failed (diff expected obtained:
 /projects/postgis/tmp/2.4_pg10w64/test_32_diff)
  regress/topogeometry_type .. ok
  regress/topojson .. ok
  regress/topologysummary .. ok
  regress/topo2.5d .. ok
  regress/totopogeom .. failed (diff expected obtained:
 /projects/postgis/tmp/2.4_pg10w64/test_37_diff)
  regress/droptopology .. ok
  regress/droptopogeometrycolumn .. ok
  regress/copytopology .. failed (diff expected obtained:
 /projects/postgis/tmp/2.4_pg10w64/test_40_diff)
  regress/createtopogeom .. ok
  regress/createtopology .. ok
  regress/gml .. ok
  regress/getnodebypoint .. ok
  regress/getedgebypoint .. ok
  regress/getfacebypoint .. ok
  regress/getringedges .. ok
  regress/gettopogeomelements .. ok
  regress/layertrigger .. ok
  regress/validatetopology .. ok
  uninstall .. ok (4662)
 Run tests: 51
 Failed: 4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3764>
