[postgis-tickets] [PostGIS] #3764: PostGIS topology failures on PostgreSQL 10
PostGIS trac at osgeo.org
Fri May 26 00:23:03 PDT 2017
  Reporter:  robe      |      Owner:  robe
      Type:  defect    |     Status:  assigned
  Priority:  blocker   |  Milestone:  PostGIS 2.4.0
 Component:  topology  |    Version:  trunk
Resolution:            |   Keywords:
Comment (by strk):
 It looks like toTopoGeom function is unable to read the correct
 geometry type from the detoasted geometry. Is this the only failure
 left ? As if this is the case I'd expect much more failures around
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3764#comment:2>
