[postgis-tickets] [PostGIS] #3759: PostgreSQL 10 failure on geometry
PostGIS trac at osgeo.org
Fri May 26 11:06:56 PDT 2017
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:  postgresql 10
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 as @pramsey pointed out it's not the float/float4 change.  Mysteriously it
 is no longer a problem on my PostgreSQL 10 and its a mystery why it is
 not.  I'll reopen if it happens again.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3759#comment:10>
