[postgis-tickets] [PostGIS] #3765: geometry regress failure
PostGIS trac at osgeo.org
Sat May 27 00:07:58 PDT 2017
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 2.4.0
Component:  buildbots  |    Version:  trunk
 Keywords:             |
 I thought the issue in #3759 was a PostgreSQL 10 one which mysteriously
 disappeared.
 But now our seeing it on winnie in her 9.5 run, but a different record
 different.
 Checking for shp2pgsql ... found
 Checking for pgsql2shp ... found
 Checking for raster2pgsql ... found
 TMPDIR is /projects/postgis/tmp/2.4.0dev_pg9.5_geos3.7.0dev_gdal2.1.3w64
 Creating database 'postgis_reg'
 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis
 PostgreSQL 9.5.2, compiled by Visual C++ build 1800, 64-bit
   Postgis 2.4.0dev - r15406 - 2017-05-26 20:07:15
   scripts 2.4.0dev r15406
   raster scripts 2.4.0dev r15406
   GEOS: 3.7.0dev-CAPI-1.11.0 8fe2ce6
   PROJ: Rel. 4.9.1, 04 March 2015
   SFCGAL: 1.3.0
   GDAL: GDAL 2.1.3, released 2017/20/01
 tickets .. failed (diff expected obtained:
 /projects/postgis/tmp/2.4.0dev_pg9.5_geos3.7.0dev_gdal2.1.3w64/test_89_diff)
 --- tickets_expected    2016-09-26 01:59:38 -0400
 /projects/postgis/tmp/2.4.0dev_pg9.5_geos3.7.0dev_gdal2.1.3w64/test_89_out
 2017-05-26 16:13:04 -0400
 @@ -284,7 +284,7 @@
 #3368|\x660001011fb98788d35ed6fbcdc831c580012b959f01469d8d0e9305ff8618ed08b1b607e302a614fe70bc4682b303b4379ab503a228eeb603e2138eb802900cc0b802ba04dab802b801a8840cb0229cca06f401c216f403a016ea05d0c301a8b301cc189226ac15ee27f811a029b40eac2ae00a902b8407c82b9e03d0e305801dfad3239504ce7e8d01e2f701f6019b04d1e2279bf901ff01
  #3375|GEOMETRYCOLLECTION(POINT(0 -7))
  #3399|1|1
 -#3399|10|10
 +#3399|10|9
  #3399|100|100
  #3399|1000|1000
  ERROR:  invalid KML representation
 Might be bot specific I guess but still concerning.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3765>
