[postgis-tickets] [PostGIS] #3926: missing upgrade path for postgis-2.2.6 to postgis-2.3.4 to postgis-2.4
PostGIS trac at osgeo.org
Thu Nov 9 01:06:35 PST 2017
  Reporter:  usama                  |      Owner:  robe
      Type:  patch                  |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.4.2
 Component:  build/upgrade/install  |    Version:  2.4.x
Resolution:  fixed                  |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16102" 16102]:
 #!CommitTicketReference repository="" revision="16102"
 Add missing 2.3.4 upgrade path (as provided by Muhammad Usama)
 Also remove 2.3 and 2.4 dev releases and add missing 2.2.6
 Closes #3926 for PostGIS 2.4.2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3926#comment:7>
