[postgis-tickets] r16124 - Explicitly specify $(PERL) to call create_unpackaged.pl otherwise at least on freebsd it fails (and backport other minor changes like remove of 9.1 which support was dropped in 2.2)
Regina Obe lr at pcorp.us
Tue Nov 28 17:12:37 PST 2017
Author: robe
Date: 2017-11-28 17:12:37 -0800 (Tue, 28 Nov 2017)
New Revision: 16124
Added:
   branches/2.3/ci/bessie/
   branches/2.3/ci/bessie/postgis_regress.sh
   branches/2.3/ci/bessie32/
   branches/2.3/ci/bessie32/postgis_regress.sh
   branches/2.3/extensions/postgis_sfcgal/Makefile.in
Closes #3938 for PostGIS 2.3.6
Also add the Bessie sisters to battery testing
Added: branches/2.3/ci/bessie/postgis_regress.sh
--- branches/2.3/ci/bessie/postgis_regress.sh	                        (rev 0)
+++ branches/2.3/ci/bessie/postgis_regress.sh	2017-11-29 01:12:37 UTC (rev 16124)
@@ -0,0 +1,8 @@
+export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
+sh autogen.sh
+./configure --with-projdir=/usr/local --with-libiconv=/usr/local --without-interrupt-tests
+make clean
+make
+export PGUSER=postgres
+export PGIS_REG_TMPDIR=~/tmp/pgis_reg_${TAG}
+make check
Added: branches/2.3/ci/bessie32/postgis_regress.sh
--- branches/2.3/ci/bessie32/postgis_regress.sh	                        (rev 0)
+++ branches/2.3/ci/bessie32/postgis_regress.sh	2017-11-29 01:12:37 UTC (rev 16124)
@@ -0,0 +1,8 @@
+sh autogen.sh
+make clean
+make
+make check
Modified: branches/2.3/extensions/postgis_sfcgal/Makefile.in
--- branches/2.3/extensions/postgis_sfcgal/Makefile.in	2017-11-29 00:18:54 UTC (rev 16123)
+++ branches/2.3/extensions/postgis_sfcgal/Makefile.in	2017-11-29 01:12:37 UTC (rev 16124)
@@ -26,18 +26,16 @@
 PG_CONFIG    =  @PG_CONFIG@
-PG91         = $(shell $(PG_CONFIG) --version | $(GREP) -qE " 8\.| 9\.0" && echo no || echo yes)
 SQL_BITS     = $(wildcard sql_bits/*.sql)
-EXTRA_CLEAN += sql/*.sql ${SQL_BITS}
+EXTRA_CLEAN += sql/*.sql ${SQL_BITS}
-ifeq ($(PG91),yes)
 all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql sql_minor_upgrade
 sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql
 	mkdir -p sql
 	cp $< $@
 sql/$(EXTENSION).sql: sql_bits/sfcgal.sql  sql_bits/sfcgal_comments.sql
 	mkdir -p sql
 	cat $^ > $@
@@ -66,7 +64,7 @@
 #then remove default values and extra junk
 sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql_bits/sfcgal.sql ../../utils/create_unpackaged.pl
 	mkdir -p sql
-	cat $< | ../../utils/create_unpackaged.pl ${EXTENSION} > $@
+	cat $< |  $(PERL) ../../utils/create_unpackaged.pl ${EXTENSION} > $@
 sql_bits/sfcgal_upgrade.sql : ../../postgis/sfcgal_upgrade.sql
 	mkdir -p sql_bits
@@ -74,17 +72,16 @@
 sql_bits/sfcgal_upgrade_minor.sql: ../postgis_extension_helper.sql sql_bits/sfcgal_upgrade.sql ../../doc/sfcgal_comments.sql ../postgis_extension_helper_uninstall.sql
 	mkdir -p sql_bits
-	echo '\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \quit' > $@
+	printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
 	cat $^ >> $@
 sql_minor_upgrade: sql_bits/sfcgal_upgrade_minor.sql
 	for OLD_VERSION in $(UPGRADEABLE_VERSIONS); do \
   	  cat $< > sql/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
 	done
 DATA = $(wildcard sql/*--*.sql)
 EXTRA_CLEAN += sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql
-endif
 distclean: clean
 	rm Makefile
