[postgis-tickets] r16129 - Clarify docs, References #3097
Paul Ramsey pramsey at cleverelephant.ca
Thu Nov 30 13:37:57 PST 2017
Author: pramsey
Date: 2017-11-30 13:37:57 -0800 (Thu, 30 Nov 2017)
New Revision: 16129
   trunk/doc/reference_processing.xml
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml	2017-11-30 20:52:56 UTC (rev 16128)
+++ trunk/doc/reference_processing.xml	2017-11-30 21:37:57 UTC (rev 16129)
@@ -3082,10 +3082,9 @@
             </para>
             <para>Availability: 2.0.0</para>
-            <para>Changed: 2.2.0 support for splitting a line by a multiline, a multipoint or (multi)polygon boundary was introduced.</para>
+            <para>Enhanced: 2.2.0 support for splitting a line by a multiline, a multipoint or (multi)polygon boundary was introduced.</para>
+        	<para>Enhanced: 2.5.0 support for splitting a polygon by a multiline was introduced.</para>
-        	<para>Enhanced: 2.5.0 support for MULTILINESTRING split blades.</para>
             <note><para>To improve the robustness of ST_Split it may be convenient to <xref linkend="ST_Snap"/> the input to the blade in advance using a very low tolerance. Otherwise the internally used coordinate grid may cause tolerance problems, where coordinates of input and blade do not fall onto each other and the input is not being split correctly (see <ulink url="http://trac.osgeo.org/postgis/ticket/2192">#2192</ulink>).</para></note>
             <note><para>
