[postgis-tickets] [PostGIS] #3824: Doc changes from Andreas Schild via transifex
PostGIS trac at osgeo.org
Mon Sep 4 07:17:05 PDT 2017
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  high           |  Milestone:  PostGIS 2.4.0
 Component:  documentation  |    Version:  2.3.x
Resolution:                 |   Keywords:
Description changed by robe:
Old description:
> This is to accumulate all of Andreas Schild current outstanding changes
> sent via transifex messaging.
> Andreas Schild created an issue for a string in the resource
> reference_raster.xml.pot
> Andreas Schild created an issue for the string: Create a set of raster
> tiles with <xref linkend="RT_ST_MakeEmptyRaster"/>. Grid dimension is
> <varname>width</varname> & <varname>height</varname>. Tile dimension
> is <varname>tilewidth</varname> & <varname>tileheight</varname>. The
> covered georeferenced area is from upper left corner
> (<varname>upperleftx</varname>, <varname>upperlefty</varname>) to lower
> right corner (<varname>upperleftx</varname> <varname>width</varname> *
> <varname>scalex</varname>, <varname>upperlefty</varname>
> <varname>height</varname> * <varname>scaley</varname>).
> meaning of "upperleftx width"? Minus sign? : "upperleftx - width *
> scalex" ?
> Andreas Schild resolved an issue for the string: The Minnesota MapServer
> is an internet web-mapping server which conforms to the OpenGIS Web
> Mapping Server specification.
> 1.3.0 OpenGIS Web Map Service (WMS) Implementation Specification WMS 1.3
> and ISO 19128 are the same documents.
> Project: PostGIS
> Resource: using_postgis_app.xml.pot
> Language: German (Germany)
> Andreas Schild resolved an issue for the string: Wrap PostgreSQL
> identifiers in quotes.
> This Sentence occurs twice in "Optional parameters used to manipulate
> database objects"
> Project: PostGIS
> Resource: using_raster_dataman.xml.pot
New description:
 meaning of "upperleftx width"? Minus sign? : "upperleftx - width * scalex"
 FIXED
 Project: PostGIS
 database objects"
 Project: PostGIS
 using_postgis_dataman.xml.pot
 Andreas Schild created an issue for the string: The above syntax will
 always build a 2D-index for geospatial objetcs on the spheroid.
 "objetcs" -> objects
 Project: PostGIS
 Resource: using_postgis_dataman.xml.pot
 Language: German
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3824#comment:4>
