[postgis-tickets] r15630 - Support PgSQL 10 on PostGIS 2.3
Paul Ramsey pramsey at cleverelephant.ca
Tue Sep 5 13:37:59 PDT 2017
Author: pramsey
Date: 2017-09-05 13:37:59 -0700 (Tue, 05 Sep 2017)
New Revision: 15630
   branches/2.3/configure.ac
   branches/2.3/libpgcommon/gserialized_gist.c
   branches/2.3/postgis/gserialized_estimate.c
   branches/2.3/postgis/gserialized_gist_nd.c
   branches/2.3/raster/rt_pg/rtpostgis.sql.in
   branches/2.3/raster/test/regress/rt_union.sql
   branches/2.3/raster/test/regress/rt_union_expected
   branches/2.3/regress/regress_selectivity.sql
   branches/2.3/topology/sql/topogeometry/totopogeom.sql.in
   branches/2.3/topology/test/regress/copytopology.sql
   branches/2.3/topology/test/regress/copytopology_expected
Modified: branches/2.3/configure.ac
--- branches/2.3/configure.ac	2017-09-05 20:33:24 UTC (rev 15629)
+++ branches/2.3/configure.ac	2017-09-05 20:37:59 UTC (rev 15630)
@@ -433,6 +433,15 @@
   PGSQL_MAJOR_VERSION=`echo $PGSQL_FULL_VERSION | sed 's/[[^0-9]]*\([[0-9]]*\).*/\1/'`
   PGSQL_MINOR_VERSION=`echo $PGSQL_FULL_VERSION | sed 's/[[^\.]]*\.\([[0-9]]*\).*/\1/'`
   PGSQL_MINOR_VERSION=`echo $PGSQL_MINOR_VERSION | sed 's/.*devel.*/0/'`
+  if test $PGSQL_MAJOR_VERSION -gt 9; then
+  	dnl ==================================================================
+  	dnl Starting with PostgreSQL 10, major is the new minor
+  	dnl This is to prevent things like 10.31 ranking higher than 11.0
+  	dnl===================================================================
+  	PGSQL_MINOR_VERSION=0
+  fi
   POSTGIS_PGSQL_VERSION="$PGSQL_MAJOR_VERSION$PGSQL_MINOR_VERSION"
   PGSQL_PKGLIBDIR=`$PG_CONFIG --pkglibdir`
Modified: branches/2.3/libpgcommon/gserialized_gist.c
--- branches/2.3/libpgcommon/gserialized_gist.c	2017-09-05 20:33:24 UTC (rev 15629)
+++ branches/2.3/libpgcommon/gserialized_gist.c	2017-09-05 20:37:59 UTC (rev 15630)
@@ -22,6 +22,10 @@
 #include "lwgeom_pg.h"       /* For debugging macros. */
 #include "gserialized_gist.h"
+#if POSTGIS_PGSQL_VERSION >= 100
+#include <float.h>
+#endif
 #define FLAGS_NDIMS_GIDX(f) ( FLAGS_GET_GEODETIC(f) ? 3 : \
                               FLAGS_GET_M(f) ? 4 : \
                               FLAGS_GET_Z(f) ? 3 : 2 )
Modified: branches/2.3/postgis/gserialized_estimate.c
--- branches/2.3/postgis/gserialized_estimate.c	2017-09-05 20:33:24 UTC (rev 15629)
+++ branches/2.3/postgis/gserialized_estimate.c	2017-09-05 20:37:59 UTC (rev 15630)
@@ -827,31 +827,52 @@
 static ND_STATS*
 pg_nd_stats_from_tuple(HeapTuple stats_tuple, int mode)
-  int stats_kind = STATISTIC_KIND_ND;
-  int rv, nvalues;
-	float4 *floatptr;
+	int stats_kind = STATISTIC_KIND_ND;
+	int rv;
 	ND_STATS *nd_stats;
-  /* If we're in 2D mode, set the kind appropriately */
-  if ( mode == 2 ) stats_kind = STATISTIC_KIND_2D;
+	/* If we're in 2D mode, set the kind appropriately */
+	if ( mode == 2 ) stats_kind = STATISTIC_KIND_2D;
-  /* Then read the geom status histogram from that */
-  rv = get_attstatsslot(stats_tuple, 0, 0, stats_kind, InvalidOid,
-                        NULL, NULL, NULL, &floatptr, &nvalues);
-  if ( ! rv ) {
-    POSTGIS_DEBUGF(2,
-            "no slot of kind %d in stats tuple", stats_kind);
-    return NULL;
+    /* Then read the geom status histogram from that */
+#if POSTGIS_PGSQL_VERSION < 100
+	float4 *floatptr;
+	int nvalues;
-  /* Clone the stats here so we can release the attstatsslot immediately */
-  nd_stats = palloc(sizeof(float) * nvalues);
-  memcpy(nd_stats, floatptr, sizeof(float) * nvalues);
+	rv = get_attstatsslot(stats_tuple, 0, 0, stats_kind, InvalidOid,
+						NULL, NULL, NULL, &floatptr, &nvalues);
+	if ( ! rv ) {
+		POSTGIS_DEBUGF(2,
+				"no slot of kind %d in stats tuple", stats_kind);
+		return NULL;
+	/* Clone the stats here so we can release the attstatsslot immediately */
+	nd_stats = palloc(sizeof(float) * nvalues);
+	memcpy(nd_stats, floatptr, sizeof(float) * nvalues);
+	/* Clean up */
+	free_attstatsslot(0, NULL, 0, floatptr, nvalues);
+#else /* PostgreSQL 10 or higher */
+	AttStatsSlot sslot;
+	rv = get_attstatsslot(&sslot, stats_tuple, stats_kind, InvalidOid,
+						 ATTSTATSSLOT_NUMBERS);
+	if ( ! rv ) {
+		POSTGIS_DEBUGF(2,
+		return NULL;
+	nd_stats = palloc(sizeof(float4) * sslot.nnumbers);
+	memcpy(nd_stats, sslot.numbers, sizeof(float4) * sslot.nnumbers);
+	free_attstatsslot(&sslot);
+#endif
-  /* Clean up */
-  free_attstatsslot(0, NULL, 0, floatptr, nvalues);
-  return nd_stats;
+    return nd_stats;
Modified: branches/2.3/postgis/gserialized_gist_nd.c
--- branches/2.3/postgis/gserialized_gist_nd.c	2017-09-05 20:33:24 UTC (rev 15629)
+++ branches/2.3/postgis/gserialized_gist_nd.c	2017-09-05 20:37:59 UTC (rev 15630)
@@ -52,6 +52,9 @@
 #include <assert.h>
+#include <float.h>
+#endif
 /* Fall back to older finite() if necessary */
 #ifndef HAVE_ISFINITE
Modified: branches/2.3/raster/rt_pg/rtpostgis.sql.in
--- branches/2.3/raster/rt_pg/rtpostgis.sql.in	2017-09-05 20:33:24 UTC (rev 15629)
+++ branches/2.3/raster/rt_pg/rtpostgis.sql.in	2017-09-05 20:37:59 UTC (rev 15630)
@@ -7037,7 +7037,7 @@
 	SELECT
 		CASE
 			WHEN strpos(s.consrc, 'ANY (ARRAY[') > 0 THEN
-				split_part((regexp_matches(s.consrc, E'ARRAY\\[(.*?){1}\\]'))[1], ',', 1)::integer
+                split_part((substring(s.consrc FROM E'ARRAY\\[(.*?){1}\\]')), ',', 1)::integer
 			ELSE
 				regexp_replace(
 					split_part(s.consrc, '= ', 2),
Modified: branches/2.3/raster/test/regress/rt_union.sql
--- branches/2.3/raster/test/regress/rt_union.sql	2017-09-05 20:33:24 UTC (rev 15629)
+++ branches/2.3/raster/test/regress/rt_union.sql	2017-09-05 20:37:59 UTC (rev 15630)
@@ -143,13 +143,13 @@
 SELECT
 	uniontype,
-	x,
-	y,
-	val
+	(pp).x,
+	(pp).y,
+	(pp).val
 FROM (
 	SELECT
 		uniontype,
-		(ST_PixelAsPoints(rast)).*
+		(ST_PixelAsPoints(rast)) AS pp
 	FROM raster_union_out
 ) foo
 ORDER BY uniontype, y, x;
Modified: branches/2.3/raster/test/regress/rt_union_expected
--- branches/2.3/raster/test/regress/rt_union_expected	2017-09-05 20:33:24 UTC (rev 15629)
+++ branches/2.3/raster/test/regress/rt_union_expected	2017-09-05 20:37:59 UTC (rev 15630)
@@ -53,9 +53,6 @@
 SUM|2|3|2
 SUM|3|3|2
 NOTICE:  No pixels found for band 1
-NOTICE:  No pixels found for band 1
 COUNT|1|1|1
 COUNT|2|1|1
 COUNT|3|1|1
Modified: branches/2.3/regress/regress_selectivity.sql
--- branches/2.3/regress/regress_selectivity.sql	2017-09-05 20:33:24 UTC (rev 15629)
+++ branches/2.3/regress/regress_selectivity.sql	2017-09-05 20:37:59 UTC (rev 15630)
@@ -1,4 +1,2141 @@
+-- Make example data
+CREATE TABLE regular_overdots_ab (
+    a integer,
+    b integer
+COPY regular_overdots_ab (a, b) FROM stdin;
+1	1
+1	1
+1	2
+1	1
+1	2
+1	3
+1	1
+1	2
+1	3
+1	4
+1	1
+1	2
+1	3
+1	4
+1	5
+1	1
+1	2
+1	3
+1	4
+1	5
+1	6
+1	1
+1	2
+1	3
+1	4
+1	5
+1	6
+1	7
+1	1
+1	2
+1	3
+1	4
+1	5
+1	6
+1	7
+1	8
+1	1
+1	2
+1	3
+1	4
+1	5
+1	6
+1	7
+1	8
+1	9
+1	1
+1	2
+1	3
+1	4
+1	5
+1	6
+1	7
+1	8
+1	9
+1	10
+1	1
+2	1
+1	1
+2	2
+1	1
+2	2
+1	3
+2	1
+1	2
+2	3
+1	1
+2	2
+1	3
+2	4
+1	1
+2	2
+1	3
+2	4
+1	5
+2	1
+1	2
+2	3
+1	4
+2	5
+1	1
+2	2
+1	3
+2	4
+1	5
+2	6
+1	1
+2	2
+1	3
+2	4
+1	5
+2	6
+1	7
+2	1
+1	2
+2	3
+1	4
+2	5
+1	6
+2	7
+1	1
+2	2
+1	3
+2	4
+1	5
+2	6
+1	7
+2	8
+1	1
+2	2
+1	3
+2	4
+1	5
+2	6
+1	7
+2	8
+1	9
+2	1
+1	2
+2	3
+1	4
+2	5
+1	6
+2	7
+1	8
+2	9
+1	1
+2	2
+1	3
+2	4
+1	5
+2	6
+1	7
+2	8
+1	9
+2	10
+1	1
+2	1
+3	1
+1	1
+2	2
+3	1
+1	2
+2	1
+3	2
+1	1
+2	2
+3	3
+1	1
+2	2
+3	3
+1	4
+2	1
+3	2
+1	3
+2	4
+3	1
+1	2
+2	3
+3	4
+1	1
+2	2
+3	3
+1	4
+2	5
+3	1
+1	2
+2	3
+3	4
+1	5
+2	1
+3	2
+1	3
+2	4
+3	5
+1	1
+2	2
+3	3
+1	4
+2	5
+3	6
+1	1
+2	2
+3	3
+1	4
+2	5
+3	6
+1	7
+2	1
+3	2
+1	3
+2	4
+3	5
+1	6
+2	7
+3	1
+1	2
+2	3
+3	4
+1	5
+2	6
+3	7
+1	1
+2	2
+3	3
+1	4
+2	5
+3	6
+1	7
+2	8
+3	1
+1	2
+2	3
+3	4
+1	5
+2	6
+3	7
+1	8
+2	1
+3	2
+1	3
+2	4
+3	5
+1	6
+2	7
+3	8
+1	1
+2	2
+3	3
+1	4
+2	5
+3	6
+1	7
+2	8
+3	9
+1	1
+2	2
+3	3
+1	4
+2	5
+3	6
+1	7
+2	8
+3	9
+1	10
+2	1
+3	2
+1	3
+2	4
+3	5
+1	6
+2	7
+3	8
+1	9
+2	10
+3	1
+1	2
+2	3
+3	4
+1	5
+2	6
+3	7
+1	8
+2	9
+3	10
+1	1
+2	1
+3	1
+4	1
+1	1
+2	2
+3	1
+4	2
+1	1
+2	2
+3	3
+4	1
+1	2
+2	3
+3	1
+4	2
+1	3
+2	1
+3	2
+4	3
+1	1
+2	2
+3	3
+4	4
+1	1
+2	2
+3	3
+4	4
+1	5
+2	1
+3	2
+4	3
+1	4
+2	5
+3	1
+4	2
+1	3
+2	4
+3	5
+4	1
+1	2
+2	3
+3	4
+4	5
+1	1
+2	2
+3	3
+4	4
+1	5
+2	6
+3	1
+4	2
+1	3
+2	4
+3	5
+4	6
+1	1
+2	2
+3	3
+4	4
+1	5
+2	6
+3	7
+4	1
+1	2
+2	3
+3	4
+4	5
+1	6
+2	7
+3	1
+4	2
+1	3
+2	4
+3	5
+4	6
+1	7
+2	1
+3	2
+4	3
+1	4
+2	5
+3	6
+4	7
+1	1
+2	2
+3	3
+4	4
+1	5
+2	6
+3	7
+4	8
+1	1
+2	2
+3	3
+4	4
+1	5
+2	6
+3	7
+4	8
+1	9
+2	1
+3	2
+4	3
+1	4
+2	5
+3	6
+4	7
+1	8
+2	9
+3	1
+4	2
+1	3
+2	4
+3	5
+4	6
+1	7
+2	8
+3	9
+4	1
+1	2
+2	3
+3	4
+4	5
+1	6
+2	7
+3	8
+4	9
+1	1
+2	2
+3	3
+4	4
+1	5
+2	6
+3	7
+4	8
+1	9
+2	10
+3	1
+4	2
+1	3
+2	4
+3	5
+4	6
+1	7
+2	8
+3	9
+4	10
+1	1
+2	1
+3	1
+4	1
+5	1
+1	1
+2	2
+3	1
+4	2
+5	1
+1	2
+2	1
+3	2
+4	1
+5	2
+1	1
+2	2
+3	3
+4	1
+5	2
+1	3
+2	1
+3	2
+4	3
+5	1
+1	2
+2	3
+3	1
+4	2
+5	3
+1	1
+2	2
+3	3
+4	4
+5	1
+1	2
+2	3
+3	4
+4	1
+5	2
+1	3
+2	4
+3	1
+4	2
+5	3
+1	4
+2	1
+3	2
+4	3
+5	4
+1	1
+2	2
+3	3
+4	4
+5	5
+1	1
+2	2
+3	3
+4	4
+5	5
+1	6
+2	1
+3	2
+4	3
+5	4
+1	5
+2	6
+3	1
+4	2
+5	3
+1	4
+2	5
+3	6
+4	1
+5	2
+1	3
+2	4
+3	5
+4	6
+5	1
+1	2
+2	3
+3	4
+4	5
+5	6
+1	1
+2	2
+3	3
+4	4
+5	5
+1	6
+2	7
+3	1
+4	2
+5	3
+1	4
+2	5
+3	6
+4	7
+5	1
+1	2
+2	3
+3	4
+4	5
+5	6
+1	7
+2	1
+3	2
+4	3
+5	4
+1	5
+2	6
+3	7
+4	1
+5	2
+1	3
+2	4
+3	5
+4	6
+5	7
+1	1
+2	2
+3	3
+4	4
+5	5
+1	6
+2	7
+3	8
+4	1
+5	2
+1	3
+2	4
+3	5
+4	6
+5	7
+1	8
+2	1
+3	2
+4	3
+5	4
+1	5
+2	6
+3	7
+4	8
+5	1
+1	2
+2	3
+3	4
+4	5
+5	6
+1	7
+2	8
+3	1
+4	2
+5	3
+1	4
+2	5
+3	6
+4	7
+5	8
+1	1
+2	2
+3	3
+4	4
+5	5
+1	6
+2	7
+3	8
+4	9
+5	1
+1	2
+2	3
+3	4
+4	5
+5	6
+1	7
+2	8
+3	9
+4	1
+5	2
+1	3
+2	4
+3	5
+4	6
+5	7
+1	8
+2	9
+3	1
+4	2
+5	3
+1	4
+2	5
+3	6
+4	7
+5	8
+1	9
+2	1
+3	2
+4	3
+5	4
+1	5
+2	6
+3	7
+4	8
+5	9
+1	1
+2	2
+3	3
+4	4
+5	5
+1	6
+2	7
+3	8
+4	9
+5	10
+1	1
+2	1
+3	1
+4	1
+5	1
+6	1
+1	1
+2	2
+3	1
+4	2
+5	1
+6	2
+1	1
+2	2
+3	3
+4	1
+5	2
+6	3
+1	1
+2	2
+3	3
+4	4
+5	1
+6	2
+1	3
+2	4
+3	1
+4	2
+5	3
+6	4
+1	1
+2	2
+3	3
+4	4
+5	5
+6	1
+1	2
+2	3
+3	4
+4	5
+5	1
+6	2
+1	3
+2	4
+3	5
+4	1
+5	2
+6	3
+1	4
+2	5
+3	1
+4	2
+5	3
+6	4
+1	5
+2	1
+3	2
+4	3
+5	4
+6	5
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+1	7
+2	1
+3	2
+4	3
+5	4
+6	5
+1	6
+2	7
+3	1
+4	2
+5	3
+6	4
+1	5
+2	6
+3	7
+4	1
+5	2
+6	3
+1	4
+2	5
+3	6
+4	7
+5	1
+6	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+1	7
+2	8
+3	1
+4	2
+5	3
+6	4
+1	5
+2	6
+3	7
+4	8
+5	1
+6	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+1	7
+2	8
+3	9
+4	1
+5	2
+6	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	9
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+1	7
+2	8
+3	9
+4	10
+5	1
+6	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+1	9
+2	10
+3	1
+4	2
+5	3
+6	4
+1	5
+2	6
+3	7
+4	8
+5	9
+6	10
+1	1
+2	1
+3	1
+4	1
+5	1
+6	1
+7	1
+1	1
+2	2
+3	1
+4	2
+5	1
+6	2
+7	1
+1	2
+2	1
+3	2
+4	1
+5	2
+6	1
+7	2
+1	1
+2	2
+3	3
+4	1
+5	2
+6	3
+7	1
+1	2
+2	3
+3	1
+4	2
+5	3
+6	1
+7	2
+1	3
+2	1
+3	2
+4	3
+5	1
+6	2
+7	3
+1	1
+2	2
+3	3
+4	4
+5	1
+6	2
+7	3
+1	4
+2	1
+3	2
+4	3
+5	4
+6	1
+7	2
+1	3
+2	4
+3	1
+4	2
+5	3
+6	4
+7	1
+1	2
+2	3
+3	4
+4	1
+5	2
+6	3
+7	4
+1	1
+2	2
+3	3
+4	4
+5	5
+6	1
+7	2
+1	3
+2	4
+3	5
+4	1
+5	2
+6	3
+7	4
+1	5
+2	1
+3	2
+4	3
+5	4
+6	5
+7	1
+1	2
+2	3
+3	4
+4	5
+5	1
+6	2
+7	3
+1	4
+2	5
+3	1
+4	2
+5	3
+6	4
+7	5
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	1
+7	2
+1	3
+2	4
+3	5
+4	6
+5	1
+6	2
+7	3
+1	4
+2	5
+3	6
+4	1
+5	2
+6	3
+7	4
+1	5
+2	6
+3	1
+4	2
+5	3
+6	4
+7	5
+1	6
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+1	8
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+1	7
+2	8
+3	1
+4	2
+5	3
+6	4
+7	5
+1	6
+2	7
+3	8
+4	1
+5	2
+6	3
+7	4
+1	5
+2	6
+3	7
+4	8
+5	1
+6	2
+7	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	1
+7	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	8
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+1	8
+2	9
+3	1
+4	2
+5	3
+6	4
+7	5
+1	6
+2	7
+3	8
+4	9
+5	1
+6	2
+7	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	9
+7	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	8
+1	9
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+1	7
+2	8
+3	9
+4	1
+5	2
+6	3
+7	4
+1	5
+2	6
+3	7
+4	8
+5	9
+6	1
+7	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	9
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+1	8
+2	9
+3	10
+4	1
+5	2
+6	3
+7	4
+1	5
+2	6
+3	7
+4	8
+5	9
+6	10
+7	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	8
+1	9
+2	10
+3	1
+4	2
+5	3
+6	4
+7	5
+1	6
+2	7
+3	8
+4	9
+5	10
+6	1
+7	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	9
+1	10
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+1	7
+2	8
+3	9
+4	10
+5	1
+6	2
+7	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	9
+7	10
+1	1
+2	1
+3	1
+4	1
+5	1
+6	1
+7	1
+8	1
+1	1
+2	2
+3	1
+4	2
+5	1
+6	2
+7	1
+8	2
+1	1
+2	2
+3	3
+4	1
+5	2
+6	3
+7	1
+8	2
+1	3
+2	1
+3	2
+4	3
+5	1
+6	2
+7	3
+8	1
+1	2
+2	3
+3	1
+4	2
+5	3
+6	1
+7	2
+8	3
+1	1
+2	2
+3	3
+4	4
+5	1
+6	2
+7	3
+8	4
+1	1
+2	2
+3	3
+4	4
+5	5
+6	1
+7	2
+8	3
+1	4
+2	5
+3	1
+4	2
+5	3
+6	4
+7	5
+8	1
+1	2
+2	3
+3	4
+4	5
+5	1
+6	2
+7	3
+8	4
+1	5
+2	1
+3	2
+4	3
+5	4
+6	5
+7	1
+8	2
+1	3
+2	4
+3	5
+4	1
+5	2
+6	3
+7	4
+8	5
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	1
+8	2
+1	3
+2	4
+3	5
+4	6
+5	1
+6	2
+7	3
+8	4
+1	5
+2	6
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	1
+8	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	1
+7	2
+8	3
+1	4
+2	5
+3	6
+4	7
+5	1
+6	2
+7	3
+8	4
+1	5
+2	6
+3	7
+4	1
+5	2
+6	3
+7	4
+8	5
+1	6
+2	7
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+1	7
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+8	7
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+1	9
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+8	7
+1	8
+2	9
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+1	7
+2	8
+3	9
+4	1
+5	2
+6	3
+7	4
+8	5
+1	6
+2	7
+3	8
+4	9
+5	1
+6	2
+7	3
+8	4
+1	5
+2	6
+3	7
+4	8
+5	9
+6	1
+7	2
+8	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	9
+7	1
+8	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	9
+8	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	8
+8	9
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+1	9
+2	10
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+1	7
+2	8
+3	9
+4	10
+5	1
+6	2
+7	3
+8	4
+1	5
+2	6
+3	7
+4	8
+5	9
+6	10
+7	1
+8	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	9
+8	10
+1	1
+2	1
+3	1
+4	1
+5	1
+6	1
+7	1
+8	1
+9	1
+1	1
+2	2
+3	1
+4	2
+5	1
+6	2
+7	1
+8	2
+9	1
+1	2
+2	1
+3	2
+4	1
+5	2
+6	1
+7	2
+8	1
+9	2
+1	1
+2	2
+3	3
+4	1
+5	2
+6	3
+7	1
+8	2
+9	3
+1	1
+2	2
+3	3
+4	4
+5	1
+6	2
+7	3
+8	4
+9	1
+1	2
+2	3
+3	4
+4	1
+5	2
+6	3
+7	4
+8	1
+9	2
+1	3
+2	4
+3	1
+4	2
+5	3
+6	4
+7	1
+8	2
+9	3
+1	4
+2	1
+3	2
+4	3
+5	4
+6	1
+7	2
+8	3
+9	4
+1	1
+2	2
+3	3
+4	4
+5	5
+6	1
+7	2
+8	3
+9	4
+1	5
+2	1
+3	2
+4	3
+5	4
+6	5
+7	1
+8	2
+9	3
+1	4
+2	5
+3	1
+4	2
+5	3
+6	4
+7	5
+8	1
+9	2
+1	3
+2	4
+3	5
+4	1
+5	2
+6	3
+7	4
+8	5
+9	1
+1	2
+2	3
+3	4
+4	5
+5	1
+6	2
+7	3
+8	4
+9	5
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	1
+8	2
+9	3
+1	4
+2	5
+3	6
+4	1
+5	2
+6	3
+7	4
+8	5
+9	6
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	1
+9	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	1
+7	2
+8	3
+9	4
+1	5
+2	6
+3	7
+4	1
+5	2
+6	3
+7	4
+8	5
+9	6
+1	7
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+8	7
+9	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	1
+8	2
+9	3
+1	4
+2	5
+3	6
+4	7
+5	1
+6	2
+7	3
+8	4
+9	5
+1	6
+2	7
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+9	7
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+9	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	8
+8	1
+9	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	1
+8	2
+9	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	1
+7	2
+8	3
+9	4
+1	5
+2	6
+3	7
+4	8
+5	1
+6	2
+7	3
+8	4
+9	5
+1	6
+2	7
+3	8
+4	1
+5	2
+6	3
+7	4
+8	5
+9	6
+1	7
+2	8
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+9	7
+1	8
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+8	7
+9	8
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+9	9
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+9	9
+1	10
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+8	7
+9	8
+1	9
+2	10
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+9	7
+1	8
+2	9
+3	10
+4	1
+5	2
+6	3
+7	4
+8	5
+9	6
+1	7
+2	8
+3	9
+4	10
+5	1
+6	2
+7	3
+8	4
+9	5
+1	6
+2	7
+3	8
+4	9
+5	10
+6	1
+7	2
+8	3
+9	4
+1	5
+2	6
+3	7
+4	8
+5	9
+6	10
+7	1
+8	2
+9	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	9
+7	10
+8	1
+9	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	9
+8	10
+9	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	8
+8	9
+9	10
+1	1
+2	1
+3	1
+4	1
+5	1
+6	1
+7	1
+8	1
+9	1
+10	1
+1	1
+2	2
+3	1
+4	2
+5	1
+6	2
+7	1
+8	2
+9	1
+10	2
+1	1
+2	2
+3	3
+4	1
+5	2
+6	3
+7	1
+8	2
+9	3
+10	1
+1	2
+2	3
+3	1
+4	2
+5	3
+6	1
+7	2
+8	3
+9	1
+10	2
+1	3
+2	1
+3	2
+4	3
+5	1
+6	2
+7	3
+8	1
+9	2
+10	3
+1	1
+2	2
+3	3
+4	4
+5	1
+6	2
+7	3
+8	4
+9	1
+10	2
+1	3
+2	4
+3	1
+4	2
+5	3
+6	4
+7	1
+8	2
+9	3
+10	4
+1	1
+2	2
+3	3
+4	4
+5	5
+6	1
+7	2
+8	3
+9	4
+10	5
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	1
+8	2
+9	3
+10	4
+1	5
+2	6
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+9	1
+10	2
+1	3
+2	4
+3	5
+4	6
+5	1
+6	2
+7	3
+8	4
+9	5
+10	6
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	1
+9	2
+10	3
+1	4
+2	5
+3	6
+4	7
+5	1
+6	2
+7	3
+8	4
+9	5
+10	6
+1	7
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+8	7
+9	1
+10	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	1
+7	2
+8	3
+9	4
+10	5
+1	6
+2	7
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+9	7
+10	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	1
+8	2
+9	3
+10	4
+1	5
+2	6
+3	7
+4	1
+5	2
+6	3
+7	4
+8	5
+9	6
+10	7
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+9	1
+10	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	1
+8	2
+9	3
+10	4
+1	5
+2	6
+3	7
+4	8
+5	1
+6	2
+7	3
+8	4
+9	5
+10	6
+1	7
+2	8
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+9	7
+10	8
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+9	9
+10	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	8
+8	9
+9	1
+10	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	9
+8	1
+9	2
+10	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	9
+7	1
+8	2
+9	3
+10	4
+1	5
+2	6
+3	7
+4	8
+5	9
+6	1
+7	2
+8	3
+9	4
+10	5
+1	6
+2	7
+3	8
+4	9
+5	1
+6	2
+7	3
+8	4
+9	5
+10	6
+1	7
+2	8
+3	9
+4	1
+5	2
+6	3
+7	4
+8	5
+9	6
+10	7
+1	8
+2	9
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+9	7
+10	8
+1	9
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+8	7
+9	8
+10	9
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+9	9
+10	10
 -- Check for error messages
 create table no_stats ( g geometry, id integer );
 create table no_stats_join ( g geometry, id integer );
@@ -8,15 +2145,12 @@
 insert into no_stats (g, id) values ('POINT(0 0)', 0);
 analyze no_stats;
 select _postgis_join_selectivity('no_stats', 'g', 'no_stats_join', 'g');
-drop table no_stats;
-drop table no_stats_join;
+drop table if exists no_stats;
+drop table if exists no_stats_join;
 -- Table with uniformly variable density, highest at 1,1, lowest at 10,10
 create table regular_overdots as
-with
-ij as ( select i, j from generate_series(1, 10) i, generate_series(1, 10) j),
-iijj as (select generate_series(1, i) as a, generate_series(1, j) b from ij)
-select st_makepoint(a, b) as g from iijj;
+  select st_makepoint(a, b) as g from regular_overdots_ab;
 -- Generate the stats
 analyze regular_overdots;
@@ -49,4 +2183,5 @@
 -- Clean
 drop table if exists regular_overdots;
+drop table if exists regular_overdots_ab;
Modified: branches/2.3/topology/sql/topogeometry/totopogeom.sql.in
--- branches/2.3/topology/sql/topogeometry/totopogeom.sql.in	2017-09-05 20:33:24 UTC (rev 15629)
+++ branches/2.3/topology/sql/topogeometry/totopogeom.sql.in	2017-09-05 20:37:59 UTC (rev 15630)
@@ -139,6 +139,7 @@
   tolerance FLOAT8;
   alayer INT;
   atopology TEXT;
+  var_dims integer;
 BEGIN
 #ifdef POSTGIS_TOPOLOGY_DEBUG
@@ -230,23 +231,31 @@
         'Unexpected feature dimension %', ST_Dimension(ageom);
   END IF;
   -- Now that we have an empty topogeometry, we loop over distinct components
   -- and add them to the definition of it. We add them as soon
   -- as possible so that each element can further edit the
   -- definition by splitting
   FOR rec IN SELECT id(tg), alayer as lyr,
-    geom, ST_Dimension(geom) as dims
-    FROM (SELECT (ST_Dump(ageom)).geom) as f
-    WHERE NOT ST_IsEmpty(geom)
+    geom, ST_Dimension(gd.geom) as dims
+    FROM ST_Dump(ageom) AS gd
+    WHERE NOT ST_IsEmpty(gd.geom)
   LOOP
-    FOR rec2 IN SELECT CASE
-       WHEN rec.dims = 0 THEN
-         topology.topogeo_addPoint(atopology, rec.geom, tolerance)
-       WHEN rec.dims = 1 THEN
-         topology.topogeo_addLineString(atopology, rec.geom, tolerance)
-       WHEN rec.dims = 2 THEN
-         topology.topogeo_addPolygon(atopology, rec.geom, tolerance)
-       END as primitive
+    -- NOTE: Switched from using case to this because of PG 10 behavior change
+    -- Using a UNION ALL only one will be processed because of the WHERE
+    -- Since the WHERE clause will be processed first
+    FOR rec2 IN SELECT primitive
+          FROM
+              SELECT topology.topogeo_addPoint(atopology, rec.geom, tolerance)
+                WHERE rec.dims = 0
+              UNION ALL
+              SELECT topology.topogeo_addLineString(atopology, rec.geom, tolerance)
+                WHERE rec.dims = 1
+              UNION ALL
+              SELECT topology.topogeo_addPolygon(atopology, rec.geom, tolerance)
+                WHERE rec.dims = 2
+            ) AS f(primitive)
     LOOP
       elem := ARRAY[rec.dims+1, rec2.primitive]::text;
       IF elems @> ARRAY[elem] THEN
Modified: branches/2.3/topology/test/regress/copytopology.sql
--- branches/2.3/topology/test/regress/copytopology.sql	2017-09-05 20:33:24 UTC (rev 15629)
+++ branches/2.3/topology/test/regress/copytopology.sql	2017-09-05 20:37:59 UTC (rev 15630)
@@ -39,13 +39,13 @@
 ORDER BY l.layer_id;
 -- Check sequences
-SELECT * from "CITY_data_UP_down".node_node_id_seq;
-SELECT * from "CITY_data_UP_down".edge_data_edge_id_seq;
-SELECT * from "CITY_data_UP_down".face_face_id_seq;
-SELECT sequence_name, last_value, start_value, increment_by, max_value, min_value, cache_value, is_cycled, is_called from "CITY_data_UP_down".layer_id_seq;
-SELECT * from "CITY_data_UP_down".topogeo_s_1;
-SELECT * from "CITY_data_UP_down".topogeo_s_2;
-SELECT * from "CITY_data_UP_down".topogeo_s_3;
+SELECT tableoid::regclass AS sequence_name, last_value,  is_called from "CITY_data_UP_down".node_node_id_seq;
+SELECT tableoid::regclass AS sequence_name, last_value,  is_called from "CITY_data_UP_down".edge_data_edge_id_seq;
+SELECT tableoid::regclass AS sequence_name, last_value,  is_called from "CITY_data_UP_down".face_face_id_seq;
+SELECT tableoid::regclass AS sequence_name, last_value,  is_called from "CITY_data_UP_down".layer_id_seq;
+SELECT tableoid::regclass AS sequence_name, last_value,  is_called  from "CITY_data_UP_down".topogeo_s_1;
+SELECT tableoid::regclass AS sequence_name, last_value,  is_called  from "CITY_data_UP_down".topogeo_s_2;
+SELECT tableoid::regclass AS sequence_name, last_value,  is_called  from "CITY_data_UP_down".topogeo_s_3;
 SELECT topology.DropTopology('CITY_data_UP_down');
 SELECT topology.DropTopology('city_data');
Modified: branches/2.3/topology/test/regress/copytopology_expected
--- branches/2.3/topology/test/regress/copytopology_expected	2017-09-05 20:33:24 UTC (rev 15629)
+++ branches/2.3/topology/test/regress/copytopology_expected	2017-09-05 20:37:59 UTC (rev 15630)
@@ -19,13 +19,13 @@
 1|CITY_data_UP_down|LAYER1|
 2|CITY_data_UP_down|LAYER2|
 3|CITY_data_UP_down|LAYER3|
-node_node_id_seq|22|1|1|9223372036854775807|1|1|0|f|t
-edge_data_edge_id_seq|26|1|1|9223372036854775807|1|1|0|f|t
-face_face_id_seq|9|1|1|9223372036854775807|1|1|0|f|t
-layer_id_seq|1|1|1|9223372036854775807|1|1|f|f
-topogeo_s_1|9|1|1|9223372036854775807|1|1|0|f|t
-topogeo_s_2|8|1|1|9223372036854775807|1|1|0|f|t
-topogeo_s_3|8|1|1|9223372036854775807|1|1|0|f|t
+"CITY_data_UP_down".node_node_id_seq|22|t
+"CITY_data_UP_down".edge_data_edge_id_seq|26|t
+"CITY_data_UP_down".face_face_id_seq|9|t
+"CITY_data_UP_down".layer_id_seq|1|f
+"CITY_data_UP_down".topogeo_s_1|9|t
+"CITY_data_UP_down".topogeo_s_2|8|t
+"CITY_data_UP_down".topogeo_s_3|8|t
 Topology 'CITY_data_UP_down' dropped
 Topology 'city_data' dropped
 #2184.1|t
