[postgis-tickets] [PostGIS] #3405: Memory leak in lwgeom_to_points
PostGIS trac at osgeo.org
Wed Sep 6 11:21:48 PDT 2017
  Reporter:  dbaston  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by pramsey):
 Well, I tried extending the semantic of lwgeom_release very slightly, to
 also free the underlying array containing the geoms, but unfortunately the
 topology code is tied to the existing semantic. It's the only major user
 of lwgeom_release, almost nothing else does. Here's what I tried
 void
 lwgeom_release(LWGEOM *lwgeom)
         if ( ! lwgeom )
                 lwerror("lwgeom_release: someone called on 0x0");
         LWDEBUGF(3, "releasing type %s", lwtype_name(lwgeom->type));
         if (lwgeom_is_collection(lwgeom))
                 LWCOLLECTION *lwcol = lwgeom_as_lwcollection(lwgeom);
                 if (lwcol && lwcol->geoms)
                         lwfree(lwcol->geoms);
         if (lwgeom_get_type(lwgeom) == POLYGONTYPE)
                 LWPOLY *lwpoly = lwgeom_as_lwpoly(lwgeom);
                 if (lwpoly && lwpoly->rings)
                         lwfree(lwpoly->rings);
         /* Drop bounding box (always a copy) */
         if ( lwgeom->bbox )
                 LWDEBUGF(3, "lwgeom_release: releasing bbox. %p",
 lwgeom->bbox);
                 lwfree(lwgeom->bbox);
         lwfree(lwgeom);
 I'm just going to do the single-point patch you proposed Dan, to fix this
 particular function. A library-wide fix on the semantics of
 cloning/freeing/releasing is beyond scope... really at any time at all.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3405#comment:9>
