[postgis-tickets] [PostGIS] #3468: ST_GeogFromText should swap longitude when latitude crosses 90 deg
PostGIS trac at osgeo.org
Wed Sep 6 11:48:32 PDT 2017
  Reporter:  tomvantilburg  |      Owner:  pramsey
      Type:  defect         |     Status:  closed
  Priority:  blocker        |  Milestone:  PostGIS 2.5.0
 Component:  postgis        |    Version:  2.2.x
Resolution:  wontfix        |   Keywords:
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 If I evaluate bearing, then altitude
 POINT(10 91) == POINT(-170 89)
 If I evaluate altitude, then bearing
 POINT(10 91) == POINT(10 89)
 I don't think there's any stronger case for flipping to the alternate
 hemisphere than there is for not doing so. That just leaves erroring out
 or not, and the case in both bearing and altitude coercion is that a
 NOTICE is raised, which seems sufficient for me.
 postgis24=# SELECT ST_AsText(ST_GeogFromText('POINT(10 91)'));
 NOTICE:  Coordinate values were coerced into range [-180 -90, 180 90] for
 GEOGRAPHY
   st_astext
  POINT(10 89)
 (1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3468#comment:8>
