[postgis-tickets] [PostGIS] #3700: test_kmeans fails on winnie often on 32-bit and sometimes on 64-bit runs
PostGIS trac at osgeo.org
Thu Sep 7 20:18:32 PDT 2017
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  reopened
  Priority:  high     |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Changes (by robe):
 * status:  closed => reopened
 * resolution:  worksforme =>
Comment:
 Nice try buddy.  Keeping this for 2.5.  I actually haven't been testing
 32-bit for a while cause I have a more pressing issue with it failing on
 shp2pgsql-gui that I haven't figured out.  So I turned off testing on
 32-bit until I've squared that away.
 Anyway like I said I think I've only seen this on windows, so it might
 have to do with the fact I compile with mingw and test against a VC++
 build that it's seeing something you aren't.  I'll reassign to myself and
 try to nail down the issue in 2.5.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3700#comment:9>
