[postgis-tickets] r15667 - Change all PARANOIA blocks to throw errors instead of
Paul Ramsey pramsey at cleverelephant.ca
Fri Sep 8 14:09:53 PDT 2017
Author: pramsey
Date: 2017-09-08 14:09:53 -0700 (Fri, 08 Sep 2017)
New Revision: 15667
   trunk/liblwgeom/lwcollection.c
   trunk/liblwgeom/lwgeom_api.c
   trunk/liblwgeom/lwgeom_geos.c
   trunk/liblwgeom/lwgeom_geos_clean.c
   trunk/liblwgeom/lwgeom_geos_split.c
   trunk/liblwgeom/lwout_wkt.c
   trunk/liblwgeom/ptarray.c
   trunk/postgis/lwgeom_box3d.c
quietly changing return values
Modified: trunk/liblwgeom/lwcollection.c
--- trunk/liblwgeom/lwcollection.c	2017-09-08 20:48:38 UTC (rev 15666)
+++ trunk/liblwgeom/lwcollection.c	2017-09-08 21:09:53 UTC (rev 15667)
@@ -219,6 +219,7 @@
 		if ( col->geoms[i] == geom )
+            lwerror("%s [%d] found duplicate geometry in collection %p == %p", __FILE__, __LINE__, col->geoms[i], geom);
 			LWDEBUGF(4, "Found duplicate geometry in collection %p == %p", col->geoms[i], geom);
 			return col;
Modified: trunk/liblwgeom/lwgeom_api.c
--- trunk/liblwgeom/lwgeom_api.c	2017-09-08 20:48:38 UTC (rev 15666)
+++ trunk/liblwgeom/lwgeom_api.c	2017-09-08 21:09:53 UTC (rev 15667)
@@ -246,11 +246,15 @@
 	int zmflag;
 #if PARANOIA_LEVEL > 0
-	if ( ! pa ) lwerror("getPoint4d_p: NULL pointarray");
+	if ( ! pa )
+		lwerror("%s [%d] NULL POINTARRAY input", __FILE__, __LINE__);
+		return 0;
 	if ( (n<0) || (n>=pa->npoints))
-		lwerror("getPoint4d_p: point offset out of range");
+		lwerror("%s [%d] called with n=%d and npoints=%d", __FILE__, __LINE__, n, pa->npoints);
 		return 0;
 #endif
@@ -335,12 +339,16 @@
 	uint8_t *ptr;
-	if ( ! pa ) return 0;
+	if ( ! pa )
+		return 0;
-		LWDEBUGF(4, "%d out of numpoint range (%d)", n, pa->npoints);
-		return 0; /*error */
+		return 0;
 #endif
@@ -386,12 +394,16 @@
 	int zmflag;
+	if ( ! pa )
+		return 0;
-		lwerror("%d out of numpoint range (%d)", n, pa->npoints);
+		return 0;
 #endif
@@ -462,12 +474,16 @@
 getPoint2d_p(const POINTARRAY *pa, int n, POINT2D *point)
+	if ( ! pa )
+		return 0;
-		lwerror("getPoint2d_p: point offset out of range");
+		return 0;
 #endif
Modified: trunk/liblwgeom/lwgeom_geos.c
--- trunk/liblwgeom/lwgeom_geos.c	2017-09-08 20:48:38 UTC (rev 15666)
+++ trunk/liblwgeom/lwgeom_geos.c	2017-09-08 21:09:53 UTC (rev 15667)
@@ -1250,7 +1250,7 @@
   if ( GEOSGeomTypeId(geos_result) != COLLECTIONTYPE )
     GEOSGeom_destroy(geos_result);
-    lwerror("Unexpected return from GEOSpolygonize");
+    lwerror("%s [%d] Unexpected return from GEOSpolygonize", __FILE__, __LINE__);
     return 0;
 #endif
@@ -1431,7 +1431,7 @@
 	if ( geom_out == NULL )
-		lwerror("serialization error");
+		lwerror("%s [%s] serialization error", __FILE__, __LINE__);
 		return NULL;
Modified: trunk/liblwgeom/lwgeom_geos_clean.c
--- trunk/liblwgeom/lwgeom_geos_clean.c	2017-09-08 20:48:38 UTC (rev 15666)
+++ trunk/liblwgeom/lwgeom_geos_clean.c	2017-09-08 21:09:53 UTC (rev 15667)
@@ -964,7 +964,7 @@
 			GEOSGeom_destroy(pd);
 			if ( loss )
-				lwnotice("Vertices lost in LWGEOM_GEOS_makeValid");
+				lwnotice("%s [%d] Vertices lost in LWGEOM_GEOS_makeValid", __FILE__, __LINE__);
 				/* return NULL */
Modified: trunk/liblwgeom/lwgeom_geos_split.c
--- trunk/liblwgeom/lwgeom_geos_split.c	2017-09-08 20:48:38 UTC (rev 15666)
+++ trunk/liblwgeom/lwgeom_geos_split.c	2017-09-08 21:09:53 UTC (rev 15667)
@@ -397,16 +397,6 @@
 		return NULL;
-	/* debugging..
-		lwnotice("Bounds poly: %s",
-		               lwgeom_to_ewkt(GEOS2LWGEOM(g1_bounds, hasZ)));
-		lwnotice("Line: %s",
-		               lwgeom_to_ewkt(GEOS2LWGEOM(g2, hasZ)));
-		lwnotice("Noded bounds: %s",
-		               lwgeom_to_ewkt(GEOS2LWGEOM(vgeoms[0], hasZ)));
 	polygons = GEOSPolygonize(vgeoms, 1);
 	if ( NULL == polygons )
@@ -426,7 +416,7 @@
 		GEOSGeom_destroy(g1_bounds);
 		GEOSGeom_destroy((GEOSGeometry*)vgeoms[0]);
 		GEOSGeom_destroy(polygons);
+		lwerror("%s [%s] Unexpected return from GEOSpolygonize", __FILE__, __LINE__);
 		return 0;
 #endif
Modified: trunk/liblwgeom/lwout_wkt.c
--- trunk/liblwgeom/lwout_wkt.c	2017-09-08 20:48:38 UTC (rev 15666)
+++ trunk/liblwgeom/lwout_wkt.c	2017-09-08 21:09:53 UTC (rev 15667)
@@ -160,7 +160,7 @@
 		return;
-	ptarray_to_wkt_sb(line->points, sb, precision, variant);
+    ptarray_to_wkt_sb(line->points, sb, precision, variant);
Modified: trunk/liblwgeom/ptarray.c
--- trunk/liblwgeom/ptarray.c	2017-09-08 20:48:38 UTC (rev 15666)
+++ trunk/liblwgeom/ptarray.c	2017-09-08 21:09:53 UTC (rev 15667)
@@ -564,14 +564,15 @@
 	if ( which > pa->npoints-1 )
-		lwerror("ptarray_removePoint: offset (%d) out of range (%d..%d)",
+		lwerror("%s [%d] offset (%d) out of range (%d..%d)", __FILE__, __LINE__,
 		        which, 0, pa->npoints-1);
 		return NULL;
 	if ( pa->npoints < 3 )
-		lwerror("ptarray_removePointe: can't remove a point from a 2-vertex POINTARRAY");
+		lwerror("%s [%d] can't remove a point from a 2-vertex POINTARRAY", __FILE__, __LINE__);
+		return NULL;
 #endif
@@ -1706,7 +1707,7 @@
 	if ( pa == NULL )
-		lwerror("getPoint got NULL pointarray");
+		lwerror("%s [%d] got NULL pointarray", __FILE__, __LINE__);
 		return NULL;
@@ -1716,7 +1717,7 @@
 	     ( n > pa->npoints ) ||
 	     ( n >= pa->maxpoints ) )
-		lwerror("getPoint_internal called outside of ptarray range (n=%d, pa.npoints=%d, pa.maxpoints=%d)",n,pa->npoints,pa->maxpoints);
+		lwerror("%s [%d] called outside of ptarray range (n=%d, pa.npoints=%d, pa.maxpoints=%d)", __FILE__, __LINE__, n, pa->npoints, pa->maxpoints);
 		return NULL; /*error */
 #endif
Modified: trunk/postgis/lwgeom_box3d.c
--- trunk/postgis/lwgeom_box3d.c	2017-09-08 20:48:38 UTC (rev 15666)
+++ trunk/postgis/lwgeom_box3d.c	2017-09-08 21:09:53 UTC (rev 15667)
@@ -170,9 +170,7 @@
 static void
 box3d_to_box_p(BOX3D *box, BOX *out)
-#if PARANOIA_LEVEL > 0
-	if (box == NULL) return;
-#endif
+	if ( ! box ) return;
 	out->low.x = box->xmin;
 	out->low.y = box->ymin;
