[postgis-tickets] r15671 - Do not call getPointxx_p on empty or null pointarray
Sandro Santilli strk at kbt.io
Fri Sep 8 14:46:17 PDT 2017
Author: strk
Date: 2017-09-08 14:46:17 -0700 (Fri, 08 Sep 2017)
New Revision: 15671
   trunk/liblwgeom/lwpoint.c
Add more 0 returns on error
Modified: trunk/liblwgeom/lwpoint.c
--- trunk/liblwgeom/lwpoint.c	2017-09-08 21:46:10 UTC (rev 15670)
+++ trunk/liblwgeom/lwpoint.c	2017-09-08 21:46:17 UTC (rev 15671)
@@ -39,24 +39,24 @@
 int
 lwpoint_getPoint2d_p(const LWPOINT *point, POINT2D *out)
-	return getPoint2d_p(point->point, 0, out);
+	return lwpoint_is_empty(point) ? 0 : getPoint2d_p(point->point, 0, out);
 /* convenience functions to hide the POINTARRAY */
 int
 lwpoint_getPoint3dz_p(const LWPOINT *point, POINT3DZ *out)
-	return getPoint3dz_p(point->point,0,out);
+	return lwpoint_is_empty(point) ? 0 : getPoint3dz_p(point->point,0,out);
 int
 lwpoint_getPoint3dm_p(const LWPOINT *point, POINT3DM *out)
-	return getPoint3dm_p(point->point,0,out);
+	return lwpoint_is_empty(point) ? 0 : getPoint3dm_p(point->point,0,out);
 int
 lwpoint_getPoint4d_p(const LWPOINT *point, POINT4D *out)
-	return getPoint4d_p(point->point,0,out);
+	return lwpoint_is_empty(point) ? 0 : getPoint4d_p(point->point,0,out);
 double
@@ -64,7 +64,10 @@
 	POINT4D pt;
 	if ( lwpoint_is_empty(point) )
 		lwerror("lwpoint_get_x called with empty geometry");
+		return 0;
 	getPoint4d_p(point->point, 0, &pt);
 	return pt.x;
@@ -74,7 +77,10 @@
 	POINT4D pt;
 		lwerror("lwpoint_get_y called with empty geometry");
+		return 0;
 	return pt.y;
@@ -84,9 +90,15 @@
 	POINT4D pt;
 		lwerror("lwpoint_get_z called with empty geometry");
+		return 0;
 	if ( ! FLAGS_GET_Z(point->flags) )
 		lwerror("lwpoint_get_z called without z dimension");
+		return 0;
 	return pt.z;
@@ -96,9 +108,15 @@
 	POINT4D pt;
 		lwerror("lwpoint_get_m called with empty geometry");
+		return 0;
 	if ( ! FLAGS_GET_M(point->flags) )
 		lwerror("lwpoint_get_m called without m dimension");
+		return 0;
 	return pt.m;
