[postgis-tickets] [PostGIS] #3838: topology.toTopoGeom fails with ERROR: XX000: SQL/MM Spatial exception - geometry crosses, when using tolerance 10 meter
PostGIS trac at osgeo.org
Sat Sep 9 02:46:43 PDT 2017
  Reporter:  laopsahl    |      Owner:  strk
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 2.3.4
 Component:  topology    |    Version:  2.3.x
Resolution:              |   Keywords:  totopogeom, ERROR:  XX000: SQL/MM
Comment (by laopsahl):
 SELECT PostGIS_Full_Version();
 postgis_full_version
  POSTGIS="2.3.0 r15146" GEOS="3.6.1-CAPI-1.10.1 r0" PROJ="Rel. 4.9.3, 15
 August 2016" GDAL="GDAL 1.11.5, released 2016/07/01" LIBXML="2.9.4"
 LIBJSON="0.12" TOPOLOGY RASTER
 (1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3838#comment:1>
