[postgis-tickets] [PostGIS] #3845: ST_LocateAlong returns error on poorly measured LRS data
PostGIS trac at osgeo.org
Tue Sep 12 17:11:25 PDT 2017
 Reporter:  pauldzy             |      Owner:  pramsey
     Type:  enhancement         |     Status:  new
 Priority:  low                 |  Milestone:  PostGIS 2.3.4
Component:  postgis             |    Version:  2.3.x
 Keywords:  ST_LocateAlong LRS  |
 I have an LRS geometry from the USGS NHD dataset whereby the final two
 points of the line have the same measure values for unknown reasons.
 This is incorrect of course but not overly invalid.  When running
 ST_LocateAlong against that final measure I get
    ERROR: Zero measure-length line encountered!
    SQL state: XX000
 Ideally I would prefer a more forgiving logic, perhaps return NULL if we
 consider this line truly invalid or perhaps just look past the duplicate
 measure to return results.  I suppose this could be tied as well to the
 lack of an LRS geometry validator in PostGIS.
 Thanks,
 Paul
 SELECT
 ST_LocateAlong(
     ST_GeomFromEWKT('SRID=5070;LINESTRINGM(460845.826402341
 773926.724512888 46.31061,460836.315093686 773887.969539204
 45.72465,460815.740949801 773767.245317281 43.92644,460817.438766447
 773729.386836077 43.37001,460817.438778068 773729.386605209 43.37001)')
    ,43.37001
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3845>
