[postgis-tickets] [PostGIS] #3113: Add curve support to ST_Simplify
PostGIS trac at osgeo.org
Fri Sep 15 06:45:53 PDT 2017
  Reporter:  aaime        |      Owner:  pramsey
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 2.1.9
 Component:  postgis      |    Version:  2.1.x
Resolution:  worksforme   |   Keywords:
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => worksforme
Comment:
 This is quite old and I'd like to know if aaime still really wants it. If
 not I'd rather close it and wait for someone else to have the need that
 implement a fugly bit of logic just for giggles:
 * for each arc, if the radius is < tolerance * X then linearize it at
 tolerance/Y
 * run DP on the result, skipping the remaining arc parts and retaining
 them unchanged
 The above would I think achieve something like a "somewhat smaller thing
 that respects the shape of the original" which I guess is the st_simplify
 contract
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3113#comment:5>
