[postgis-tickets] r15772 - Remove the local hacks for float rounding and go
Paul Ramsey pramsey at cleverelephant.ca
Tue Sep 19 14:02:06 PDT 2017
Author: pramsey
Date: 2017-09-19 14:02:06 -0700 (Tue, 19 Sep 2017)
New Revision: 15772
   trunk/liblwgeom/liblwgeom.h.in
   trunk/liblwgeom/lwgeom_api.c
   trunk/regress/lwgeom_regress_expected
with system level functions, that are hopefully
more optimized. Also, this seems to provide more
correct results than the old code!
(Closes #3852)
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in	2017-09-19 18:08:45 UTC (rev 15771)
+++ trunk/liblwgeom/liblwgeom.h.in	2017-09-19 21:02:06 UTC (rev 15772)
@@ -651,7 +651,7 @@
 extern uint32_t gserialized_max_header_size(void);
-* Returns the size in bytes of the header, from the start of the
+* Returns the size in bytes of the header, from the start of the
 * object up to the type number.
 extern uint32_t gserialized_header_size(const GSERIALIZED *gser);
@@ -710,10 +710,10 @@
 * Return -1 if g1 is "less than" g2, 1 if g1 is "greater than"
 * g2 and 0 if g1 and g2 are the "same". Equality is evaluated
-* with a memcmp and size check. So it is possible that two
-* identical objects where one lacks a bounding box could be
+* with a memcmp and size check. So it is possible that two
+* identical objects where one lacks a bounding box could be
 * evaluated as non-equal initially. Greater and less than
-* are evaluated by calculating a sortable key from the center
+* are evaluated by calculating a sortable key from the center
 * point of the object bounds.
 extern int gserialized_cmp(const GSERIALIZED *g1, const GSERIALIZED *g2);
@@ -1165,8 +1165,6 @@
 extern float  next_float_down(double d);
 extern float  next_float_up(double d);
-extern double next_double_down(float d);
-extern double next_double_up(float d);
 /* general utilities 2D */
 extern double  distance2d_pt_pt(const POINT2D *p1, const POINT2D *p2);
Modified: trunk/liblwgeom/lwgeom_api.c
--- trunk/liblwgeom/lwgeom_api.c	2017-09-19 18:08:45 UTC (rev 15771)
+++ trunk/liblwgeom/lwgeom_api.c	2017-09-19 21:02:06 UTC (rev 15772)
@@ -47,115 +47,15 @@
- * BOX routines
- * returns the float thats very close to the input, but <=
- *  handles the funny differences in float4 and float8 reps.
-typedef union
+inline float
+next_float_down(double d)
-	float value;
-	uint32_t word;
-} ieee_float_shape_type;
-#define GET_FLOAT_WORD(i,d)			\
-	do {					\
-		ieee_float_shape_type gf_u;	\
-		gf_u.value = (d);		\
-		(i) = gf_u.word;		\
-	} while (0)
-#define SET_FLOAT_WORD(d,i)			\
-	do {					\
-		ieee_float_shape_type sf_u;	\
-		sf_u.word = (i);		\
-		(d) = sf_u.value;		\
-	} while (0)
- * Returns the next smaller or next larger float
- * from x (in direction of y).
-static float
-nextafterf_custom(float x, float y)
-	int hx,hy,ix,iy;
-	GET_FLOAT_WORD(hx,x);
-	GET_FLOAT_WORD(hy,y);
-	ix = hx&0x7fffffff;             /* |x| */
-	iy = hy&0x7fffffff;             /* |y| */
-	if ((ix>0x7f800000) ||   /* x is nan */
-	        (iy>0x7f800000))     /* y is nan */
-		return x+y;
-	if (x==y) return y;              /* x=y, return y */
-	if (ix==0)
-		/* x == 0 */
-		SET_FLOAT_WORD(x,(hy&0x80000000)|1);/* return +-minsubnormal */
-		y = x*x;
-		if (y==x) return y;
-		else return x;   /* raise underflow flag */
-	if (hx>=0)
-		/* x > 0 */
-		if (hx>hy)
-			/* x > y, x -= ulp */
-			hx -= 1;
-		else
-			/* x < y, x += ulp */
-			hx += 1;
-	else
-		/* x < 0 */
-		if (hy>=0||hx>hy)
-			/* x < y, x -= ulp */
-			hx -= 1;
-		else
-			/* x > y, x += ulp */
-			hx += 1;
-	hy = hx&0x7f800000;
-	if (hy>=0x7f800000) return x+x;  /* overflow  */
-	if (hy<0x00800000)
-		/* underflow */
-		y = x*x;
-		if (y!=x)
-			/* raise underflow flag */
-			SET_FLOAT_WORD(y,hx);
-			return y;
-	SET_FLOAT_WORD(x,hx);
-	return x;
-float next_float_down(double d)
 	float result  = d;
-	if ( ((double) result) <=d)
+	if ( ((double)result) <=d )
 		return result;
-	return nextafterf_custom(result, result - 1000000);
+	return nextafterf(result, -1*FLT_MAX);
@@ -163,49 +63,20 @@
  * Returns the float thats very close to the input, but >=.
-float
+inline float
 	float result  = d;
-	if ( ((double) result) >=d)
+	if ( ((double)result) >=d )
 		return result;
-	return nextafterf_custom(result, result + 1000000);
+	return nextafterf(result, FLT_MAX);
- * Returns the double thats very close to the input, but <.
-double
-next_double_down(float d)
-	double result  = d;
-	if ( result < d)
-		return result;
- * Returns the double thats very close to the input, but >
-double
-next_double_up(float d)
-	if ( result > d)
-		return result;
  * POINTARRAY support functions
Modified: trunk/regress/lwgeom_regress_expected
--- trunk/regress/lwgeom_regress_expected	2017-09-19 18:08:45 UTC (rev 15771)
+++ trunk/regress/lwgeom_regress_expected	2017-09-19 21:02:06 UTC (rev 15772)
@@ -15,9 +15,9 @@
 #3069|BOX(0 0,1 1)
 #3069|BOX(1 1,1 1)
 #3069|BOX(0 0,1 1)
-BoundingDiagonal1|SRID=4326;LINESTRING(999999986991104 999999986991104,999999986991104 999999986991104)
+BoundingDiagonal1|SRID=4326;LINESTRING(999999986991104 999999986991104,1.00000005409997e+15 1.00000005409997e+15)
 BoundingDiagonal2|SRID=4326;LINESTRING(1e+15 1e+15,1e+15 1e+15)
-BoundingDiagonal3|SRID=4326;LINESTRING(999999986991104 999999986991104,999999986991104 999999986991104)
+BoundingDiagonal3|SRID=4326;LINESTRING(999999986991104 999999986991104,1.00000005409997e+15 1.00000005409997e+15)
 BoundingDiagonal4|SRID=3857;LINESTRING(-1 -2 -8 2,1 2 3 9)
 BoundingDiagonal5|SRID=3857;LINESTRINGM(4 4 0,5 4 1)
 BoundingDiagonal6|SRID=3857;LINESTRINGM EMPTY
