[postgis-tickets] [PostGIS] #3853: datum slicing for bounding box retrieval is busted
PostGIS trac at osgeo.org
Wed Sep 20 08:46:15 PDT 2017
  Reporter:  pramsey      |      Owner:  pramsey
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 2.4.0
 Component:  postgis      |    Version:  trunk
Resolution:  fixed        |   Keywords:
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"15778" 15778]:
 #!CommitTicketReference repository="" revision="15778"
 Remove slicing logic from bounding box reader and
 note why inline with the code so it can be done "right"
 in a larger re-work of serialization (postgis 3) that
 supports postgis-side compression. (Closes #3853)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3853#comment:1>
