[postgis-tickets] [PostGIS] #3859: Remove rt* targets from postgis extension Makefile if --without-raster is set
PostGIS trac at osgeo.org
Sat Sep 23 20:43:50 PDT 2017
set
  Reporter:  giohappy               |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.4.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  wontfix                |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 You can't make postgis extension without raster included because then it
 wouldn't be the same extension.  We decided on this a long time ago.
 Now I'm willing to entertain the idea of having an extension that is not
 called postgis.
 something like postgis_core so it's clear it doesn't have raster in it.
 Others didn't like that idea.  Anyrate it's not something we are going to
 do in PostGIS 2.4, might be a reconsideration for PostGIS 2.5.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3859#comment:1>
