[postgis-tickets] [PostGIS] #3859: Remove rt* targets from postgis extension Makefile if --without-raster is set
PostGIS trac at osgeo.org
Mon Sep 25 00:57:57 PDT 2017
set
  Reporter:  giohappy               |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.4.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  wontfix                |   Keywords:
Comment (by robe):
 giohappy it could have been a while ago, now it's really hard to change
 and less reason now that most are building with GDAL.
 BTW this is Regina not Sandro.  Build/upgrade/install tickets
 automatically get assigned to Sandro.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3859#comment:3>
