[postgis-tickets] r15831 - Remove trailing blank from postgis_config.h.in, prevent them
Sandro Santilli strk at kbt.io
Tue Sep 26 09:23:29 PDT 2017
Author: strk
Date: 2017-09-26 09:23:29 -0700 (Tue, 26 Sep 2017)
New Revision: 15831
   branches/2.4/GNUmakefile.in
   branches/2.4/postgis_config.h.in
Modified: branches/2.4/GNUmakefile.in
--- branches/2.4/GNUmakefile.in	2017-09-26 16:20:30 UTC (rev 15830)
+++ branches/2.4/GNUmakefile.in	2017-09-26 16:23:29 UTC (rev 15831)
@@ -41,7 +41,6 @@
 	! find . -name '*.c' -o -name '*.h' | \
 		grep -v lwin_wkt_lex.c | \
 		grep -v lwin_wkt_parse | \
-		grep -v postgis_config.h | \
 		grep -v postgis/sqldefines.h | \
 		xargs grep -n '[[:space:]]$$'
Modified: branches/2.4/postgis_config.h.in
--- branches/2.4/postgis_config.h.in	2017-09-26 16:20:30 UTC (rev 15830)
+++ branches/2.4/postgis_config.h.in	2017-09-26 16:23:29 UTC (rev 15831)
@@ -3,7 +3,7 @@
 #include "postgis_svn_revision.h"
-/* Manually manipulate the POSTGIS_DEBUG_LEVEL, it is not affected by the
+/* Manually manipulate the POSTGIS_DEBUG_LEVEL, it is not affected by the
    configure process */
 #define POSTGIS_DEBUG_LEVEL 0
