[postgis-tickets] [PostGIS] #3818: Triangle WKT importer checks the M dimension to determine if the triangle is closed. Other geometyr types don't
PostGIS trac at osgeo.org
Tue Sep 26 10:04:18 PDT 2017
  Reporter:  rouault  |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 2.3.4
 Component:  postgis  |    Version:  2.3.x
Resolution:  fixed    |   Keywords:
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"15835" 15835]:
 #!CommitTicketReference repository="" revision="15835"
 Triangles un-closed in M should be WKT parseable (Closes #3818)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3818#comment:3>
