[postgis-tickets] r15841 - Complete source TODO item, use double access for ptarray reversal
Paul Ramsey pramsey at cleverelephant.ca
Tue Sep 26 14:23:19 PDT 2017
Author: pramsey
Date: 2017-09-26 14:23:19 -0700 (Tue, 26 Sep 2017)
New Revision: 15841
   trunk/liblwgeom/ptarray.c
Modified: trunk/liblwgeom/ptarray.c
--- trunk/liblwgeom/ptarray.c	2017-09-26 20:55:01 UTC (rev 15840)
+++ trunk/liblwgeom/ptarray.c	2017-09-26 21:23:19 UTC (rev 15841)
@@ -342,23 +342,23 @@
 void
 ptarray_reverse(POINTARRAY *pa)
-	/* TODO change this to double array operations once point array is double aligned */
-	POINT4D pbuf;
 	int i;
-	int ptsize = ptarray_point_size(pa);
 	int last = pa->npoints-1;
 	int mid = pa->npoints/2;
-	for (i=0; i<mid; i++)
+	double *d = (double*)(pa->serialized_pointlist);
+	int j;
+	int ndims = FLAGS_NDIMS(pa->flags);
+	for (i = 0; i < mid; i++)
-		uint8_t *from, *to;
-		from = getPoint_internal(pa, i);
-		to = getPoint_internal(pa, (last-i));
-		memcpy((uint8_t *)&pbuf, to, ptsize);
-		memcpy(to, from, ptsize);
-		memcpy(from, (uint8_t *)&pbuf, ptsize);
+		for (j = 0; j < ndims; j++)
+			double buf;
+			buf = d[i*ndims+j];
+			d[i*ndims+j] = d[(last-i)*ndims+j];
+			d[(last-i)*ndims+j] = buf;
@@ -1818,27 +1818,23 @@
 void
 ptarray_scale(POINTARRAY *pa, const POINT4D *fact)
-  int i;
-  POINT4D p4d;
-  LWDEBUG(3, "ptarray_scale start");
-  for (i=0; i<pa->npoints; ++i)
-    getPoint4d_p(pa, i, &p4d);
-    p4d.x *= fact->x;
-    p4d.y *= fact->y;
-    p4d.z *= fact->z;
-    p4d.m *= fact->m;
-    ptarray_set_point4d(pa, i, &p4d);
-  LWDEBUG(3, "ptarray_scale end");
+	int i;
+	POINT4D p4d;
+	LWDEBUG(3, "ptarray_scale start");
+	for (i=0; i<pa->npoints; i++)
+		getPoint4d_p(pa, i, &p4d);
+		p4d.x *= fact->x;
+		p4d.y *= fact->y;
+		p4d.z *= fact->z;
+		p4d.m *= fact->m;
+		ptarray_set_point4d(pa, i, &p4d);
+	LWDEBUG(3, "ptarray_scale end");
 int
-ptarray_startpoint(const POINTARRAY* pa, POINT4D* pt)
+ptarray_startpoint(const POINTARRAY *pa, POINT4D *pt)
 	return getPoint4d_p(pa, 0, pt);
