[postgis-tickets] [PostGIS] #3868: README says 3.3+ required, configure enforces 3.4+
PostGIS trac at osgeo.org
Fri Sep 29 06:25:05 PDT 2017
 Reporter:  pramsey  |      Owner:  robe
     Type:  defect   |     Status:  assigned
 Priority:  blocker  |  Milestone:  PostGIS 2.4.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 From README
 * GEOS (Required, Version 3.3.0 or higher
   - 3.4+ is strongly recommended and needed for full features):
 from configure
 dnl Ensure that we are using GEOS >= 3.4.0
 AC_MSG_RESULT([checking GEOS version... $GEOS_FULL_VERSION])
 if test ! "$GEOS_NUMERIC_VERSION" -ge 30400; then
     AC_MSG_ERROR([PostGIS requires GEOS >= 3.4.0])
 fi
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3868>
