[postgis-tickets] [PostGIS] #3869: PostGIS fails to link with the gold linker due to underlinking
PostGIS trac at osgeo.org
Fri Sep 29 08:12:06 PDT 2017
 Reporter:  mjo      |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.3.4
Component:  postgis  |    Version:  trunk
 Keywords:           |
 "gold" is a modern linker intended to (eventually) replace the traditional
 "BFD" linker:
 https://en.wikipedia.org/wiki/Gold_%28linker%29
 However, gold is more strict about underlinking than the BFD linker was,
 and unused symbols are omitted from the resulting binary. This causes a
 problem for PostGIS, where something -- probably liblwgeom.so -- is using
 symbols from the math library but is not linking it in with "-lm". I've
 reported this on the Gentoo bug tracker along with a full build log:
   https://bugs.gentoo.org/show_bug.cgi?id=632354
 The fix is most likely simple, to add "-lm" to the linker command of any
 binary that uses the math functions. I've confirmed that this affects the
 latest SVN revision, and would be happy to test a patch.
 For convenience, I'll reproduce the error message here:
 libtool: link: x86_64-pc-linux-gnu-gcc -I ../liblwgeom -march=native -O2
 -pipe -fPIC -DPIC -Wall -Wmissing-prototypes shpopen.o dbfopen.o getopt.o
 shpcommon.o safileio.o shp2pgsql-core.o shp2pgsql-cli.o -o .libs/shp2pgsql
 -Wl,-O1 -Wl,-rpath -Wl,/usr/lib64/postgresql-9.4/lib64 -Wl,--enable-new-
 dtags ../liblwgeom/.libs/liblwgeom.so -L/usr/lib64 -lgeos_c -lproj
 -ljson-c -L/usr/lib64/postgresql-9.4/lib64 -Wl,--as-needed -lc
 ../liblwgeom/.libs/liblwgeom.so: error: undefined reference to 'sqrt'
 ../liblwgeom/.libs/liblwgeom.so: error: undefined reference to 'atan'
 ../liblwgeom/.libs/liblwgeom.so: error: undefined reference to 'floor'
 ../liblwgeom/.libs/liblwgeom.so: error: undefined reference to 'atan2'
 ../liblwgeom/.libs/liblwgeom.so: error: undefined reference to 'sincos'
 ../liblwgeom/.libs/liblwgeom.so: error: undefined reference to 'remainder'
 ../liblwgeom/.libs/liblwgeom.so: error: undefined reference to 'acos'
 ../liblwgeom/.libs/liblwgeom.so: error: undefined reference to 'asin'
 ../liblwgeom/.libs/liblwgeom.so: error: undefined reference to 'sin'
 ../liblwgeom/.libs/liblwgeom.so: error: undefined reference to 'cos'
 ../liblwgeom/.libs/liblwgeom.so: error: undefined reference to 'log10'
 ../liblwgeom/.libs/liblwgeom.so: error: undefined reference to 'log'
 ../liblwgeom/.libs/liblwgeom.so: error: undefined reference to 'tan'
 collect2: error: ld returned 1 exit status
 make[1]: *** [Makefile:103: shp2pgsql] Error 1
 make[1]: Leaving directory '/var/tmp/portage/dev-
 db/postgis-2.1.8-r1/work/postgis-2.1.8/loader'
 (Adding "-lm" to the linker command above fixes the problem, but that may
 not be the best place to do it if liblwgeom is the one trying to use the
 math functions.)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3869>
