[postgis-tickets] [PostGIS] #3870: topology tests failing and crashing server on 32-bit winnie tests
PostGIS trac at osgeo.org
Sat Sep 30 18:54:12 PDT 2017
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 2.5.0
 Component:  topology  |    Version:  trunk
Resolution:            |   Keywords:
Comment (by robe):
 Sadly this did not fix it. It's all of winnie's 32-bits failing.  The
 64-bits are fine.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3870#comment:2>
