[postgis-tickets] [PostGIS] #4062: Git lab ci need to be able to test 2.2 or turn off
PostGIS trac at osgeo.org
Sun Apr 1 21:27:03 PDT 2018
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 2.2.7
Component:  buildbots  |    Version:  2.2.x
 Keywords:             |
 First of all I had to upgrade Git lab ci to use 9.6, because for the image
 in use, there is no lower PostgreSQL version it seems.
 However we can't use 9.6 because 2.2 only is guaranteed to support
 compile, and you can see why cause topology fails
 https://gitlab.com/postgis/postgis/-/jobs/60603994
 regress/gml .. failed (diff expected obtained: /tmp/pgis_reg/test_42_diff)
 --- regress/gml_expected        2018-04-02 03:55:01.000000000 +0000
 +++ /tmp/pgis_reg/test_42_out   2018-04-02 04:01:18.000000000 +0000
 @@ -55,8 +55,8 @@
  S3-visited|<TopoPoint><directedNode xlink:href="#N6" /></TopoPoint>
  R1-visited|<TopoCurve><directedEdge><Edge id="E9"><directedNode
 orientation="-"><Node id="N15"/></directedNode><directedNode
 xlink:href="#N14" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>9 14 21
 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge
 orientation="-"><Edge id="E10"><directedNode orientation="-"><Node
 id="N13"/></directedNode><directedNode xlink:href="#N14"
 srsName="EPSG:4326"><segments><LineStringSegment><posList>35 14 21
 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></TopoCurve>
  N1N6N14-visited|<TopoPoint><directedNode><Node
 id="N1"><pointProperty><Point srsName="EPSG:4326"><pos>8
 30</pos></Point></pointProperty></Node></directedNode><directedNode
 xlink:href="#N6" /><directedNode xlink:href="#N14" /></TopoPoint>
 -P2-visited|<TopoSurface><directedFace><Face id="F4"><directedEdge
 orientation="-"><Edge id="E7"><directedNode orientation="-"
 xlink:href="#N17" /><directedNode><Node
 id="N18"/></directedNode><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>21 22 35
 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge><Edge
 id="E17"><directedNode orientation="-" xlink:href="#N13" /><directedNode
 xlink:href="#N18" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>35 14 35
 orientation="-" xlink:href="#E10" /><directedEdge orientation="-"
 xlink:href="#E19" /></Face></directedFace><directedFace><Face
 id="F7"><directedEdge xlink:href="#E10" /><directedEdge><Edge
 id="E18"><directedNode orientation="-"><Node
 id="N10"/></directedNode><directedNode xlink:href="#N13"
 srsName="EPSG:4326"><segments><LineStringSegment><posList>35 6 35
 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge><Edge
 id="E13"><directedNode orientation="-" xlink:href="#N9" /><directedNode
 xlink:href="#N10" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>21 6 35
 6</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge
 orientation="-" xlink:href="#E20" /></Face></directedFace></TopoSurface>
 -P1-visited|<TopoSurface><directedFace><Face id="F3"><directedEdge
 orientation="-"><Edge id="E6"><directedNode orientation="-"><Node
 id="N16"/></directedNode><directedNode><Node
 id="N17"/></directedNode><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>9 22 21
 id="E19"><directedNode orientation="-" xlink:href="#N14" /><directedNode
 xlink:href="#N17" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>21 14 21
 xlink:href="#E9" /><directedEdge orientation="-"><Edge
 id="E21"><directedNode orientation="-" xlink:href="#N15" /><directedNode
 xlink:href="#N16" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>9 14 9
 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></Face></directedFace><directedFace><Face
 id="F6"><directedEdge orientation="-" xlink:href="#E9"
 /><directedEdge><Edge id="E20"><directedNode orientation="-"><Node
 id="N9"/></directedNode><directedNode xlink:href="#N14"
 srsName="EPSG:4326"><segments><LineStringSegment><posList>21 6 21
 id="E12"><directedNode orientation="-"><Node
 id="N8"/></directedNode><directedNode xlink:href="#N9"
 srsName="EPSG:4326"><segments><LineStringSegment><posList>9 6 21
 orientation="-"><Edge id="E22"><directedNode orientation="-"
 xlink:href="#N8" /><directedNode xlink:href="#N15" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>9 6 9
 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></Face></directedFace></TopoSurface>
 +P2-visited|<TopoSurface><directedFace><Face id="F4"><directedEdge
 orientation="-"><Edge id="E7"><directedNode orientation="-"><Node
 id="N17"/></directedNode><directedNode><Node
 orientation="-" xlink:href="#E10" /><directedEdge orientation="-"><Edge
 id="E13"><directedNode orientation="-"><Node
 id="N9"/></directedNode><directedNode xlink:href="#N10"
 orientation="-"><Edge id="E20"><directedNode orientation="-"
 xlink:href="#N9" /><directedNode xlink:href="#N14" /><curveProperty><Curve
 +P1-visited|<TopoSurface><directedFace><Face id="F3"><directedEdge
 id="N16"/></directedNode><directedNode xlink:href="#N17"
 xlink:href="#E19" /><directedEdge xlink:href="#E9" /><directedEdge
 orientation="-"><Edge id="E21"><directedNode orientation="-"
 xlink:href="#N15" /><directedNode xlink:href="#N16"
 id="F6"><directedEdge orientation="-" xlink:href="#E9" /><directedEdge
 xlink:href="#E20" /><directedEdge><Edge id="E12"><directedNode
 orientation="-"><Node id="N8"/></directedNode><directedNode
 xlink:href="#N9" /><curveProperty><Curve
  F3F4-visited|<TopoSurface><directedFace xlink:href="#F3" /><directedFace
 xlink:href="#F4" /></TopoSurface>
  E7E8-visited|<TopoCurve><directedEdge xlink:href="#E7"
 /><directedEdge><Edge id="E8"><directedNode orientation="-"
 xlink:href="#N18" /><directedNode><Node
 id="N19"/></directedNode><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>35 22 47
 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></TopoCurve>
  P3-visited-idprefix|<TopoSurface><directedFace><Face
 id="cd-F5"><directedEdge orientation="-" xlink:href="#cd-E8"
 /><directedEdge><Edge id="cd-E15"><directedNode orientation="-"><Node
 id="cd-N12"/></directedNode><directedNode xlink:href="#cd-N19"
 srsName="EPSG:4326"><segments><LineStringSegment><posList>47 14 47
 id="cd-E11"><directedNode orientation="-" xlink:href="#cd-N13"
 /><directedNode xlink:href="#cd-N12" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>35 14 47
 orientation="-" xlink:href="#cd-E17"
 /></Face></directedFace><directedFace><Face id="cd-F8"><directedEdge
 orientation="-" xlink:href="#cd-E11" /><directedEdge><Edge
 id="cd-E16"><directedNode orientation="-"><Node
 id="cd-N11"/></directedNode><directedNode xlink:href="#cd-N12"
 srsName="EPSG:4326"><segments><LineStringSegment><posList>47 6 47
 id="cd-E14"><directedNode orientation="-" xlink:href="#cd-N10"
 /><directedNode xlink:href="#cd-N11" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>35 6 47
 orientation="-" xlink:href="#cd-E18"
  regress/getnodebypoint .. ok
  regress/getedgebypoint .. ok
  regress/getfacebypoint .. ok
  regress/getringedges .. ok
  regress/gettopogeomelements .. ok
  regress/layertrigger .. ok
  regress/validatetopology .. ok
  uninstall .  /builds/postgis/postgis/regress/00-regress-
 install/share/contrib/postgis/uninstall_topology.sql
 install/share/contrib/postgis/uninstall_postgis.sql
 . ok (4581)
 Run tests: 50
 Failed: 1
 make[2]: *** [check] Error 1
 Makefile:84: recipe for target 'check' failed
 make[2]: Leaving directory '/builds/postgis/postgis/topology/test'
 Makefile:109: recipe for target 'check' failed
 make[1]: Leaving directory '/builds/postgis/postgis/topology'
 make[1]: *** [check] Error 2
 make: *** [check] Error 1
 GNUmakefile:16: recipe for target 'check' failed
 ERROR: Job failed: exit code 1
 Can we upgrade gitlab to use same image as drone so it can test 9.5?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4062>
