[postgis-tickets] r16517 - Update in prep for 2.4.7
Regina Obe lr at pcorp.us
Sun Apr 1 09:57:28 PDT 2018
Author: robe
Date: 2018-04-01 21:57:28 -0700 (Sun, 01 Apr 2018)
New Revision: 16517
   branches/2.4/ChangeLog
   branches/2.4/HOWTO_RELEASE
   branches/2.4/NEWS
   branches/2.4/README.postgis
   branches/2.4/Version.config
   branches/2.4/doc/release_notes.xml
   branches/2.4/extensions/upgradeable_versions.mk
Modified: branches/2.4/ChangeLog
--- branches/2.4/ChangeLog	2018-04-02 03:58:29 UTC (rev 16516)
+++ branches/2.4/ChangeLog	2018-04-02 04:57:28 UTC (rev 16517)
@@ -1,3 +1,257 @@
+2018-03-28 08:53  Regina Obe <lr at pcorp.us>
+	* [r16504] NEWS, doc/reference_raster.xml,
+	  raster/rt_pg/rtpg_mapalgebra.c, raster/test/regress/tickets.sql,
+	  raster/test/regress/tickets_expected: Fix crasher in raster when
+	  fed an empty raster (note was tempted to change the def of empty
+	  raster to include raster with no bands but not sure where else
+	  that is used, so just revised the clip check to not try to clip
+	  if no bands).
+	  References #3055 for PostGIS 2.4.4,
+	  also minor doc fix references #2925 for PostGIS 2.4.4
+2018-03-27 17:36  Darafei Praliaskouski <me at komzpa.net>
+	* [r16500] NEWS, liblwgeom/lwlinearreferencing.c: ST_CPAWithin
+	  precision fix
+	  Closes #4032
+2018-03-25 03:33  Regina Obe <lr at pcorp.us>
+	* [r16498] NEWS, extensions/postgis_extension_helper.sql: upgrade
+	  support for PostgreSQL 11
+	  closes #4044 for PostGIS 2.4.4
+2018-03-24 03:01  Regina Obe <lr at pcorp.us>
+	* [r16496] NEWS: change sorting of tickets to be nuermic by ticket
+	  number. Add in missing tickets
+2018-03-24 02:17  Regina Obe <lr at pcorp.us>
+	* [r16495] doc/installation.xml: note in docs about soft upgrade
+	  that legacy.sql must be rerun for each minor.
+	  Closes #2960 for PostGIS 2.4.4
+2018-03-24 00:00  Daniel Baston <dbaston at gmail.com>
+	* [r16491] liblwgeom/lwgeom_geos_cluster.c, regress/tickets.sql,
+	  regress/tickets_expected: Avoid dropping SRID in
+	  ST_ClusterIntersecting
+	  References #4055
+2018-03-23 06:35  Regina Obe <lr at pcorp.us>
+	* [r16484] ci/winnie/build_postgis.sh,
+	  ci/winnie/package_postgis.sh, ci/winnie/regress_postgis.sh:
+	  change to use GDAL 2.2.4, 3.6.2 (for packaging) but keep 3.7.0dev
+	  for regress testing
+2018-03-23 00:09  Regina Obe <lr at pcorp.us>
+	* [r16482] NEWS, postgis/geography.sql.in: schema qualify geography
+	  functions (including ST_Buffer)
+	  References #4052 for PostGIS 2.4.4
+2018-03-18 22:43  Regina Obe <lr at pcorp.us>
+	* [r16477] ci/debbie/postgis_release_docs.sh: Seems sometimes the
+	  postgis_svn_revision.h gets wiped out, so end up with no svn
+	  number.
+	  Explicitly call svn_repo_revision.pl to ensure we have an svn
+	  number to read
+	  References #4047 for PostGIS 2.4
+2018-03-18 09:10  Regina Obe <lr at pcorp.us>
+	* [r16474] ci/debbie/postgis_release_docs.sh: this for sure will
+	  fix revision # this time I tested before hand
+2018-03-18 05:16  Regina Obe <lr at pcorp.us>
+	* [r16472] ci/debbie/postgis_release_docs.sh: variable typo
+2018-03-18 05:12  Regina Obe <lr at pcorp.us>
+	* [r16470] ci/debbie/postgis_release_docs.sh: Add logic to show git
+	  log timestamp in UTC instead of Unix timestamp and put in svn
+	  revision number
+2018-02-26 20:04  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16425] liblwgeom/lwin_wkt_lex.c: Update lexer generated file
+	  References #4017
+2018-02-26 20:03  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16424] NEWS, liblwgeom/lwin_wkt_lex.l: Fix memory corruption in
+	  case where lexer is interrupted mid-process
+	  References #4017
+	  For 2.4 branch
+2018-02-26 18:25  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16420] NEWS, liblwgeom/lwlinearreferencing.c: Use more precise
+	  bounds when testing overlap of temporal ranges.
+	  For 2.4, references #4025
+2018-02-25 14:54  Sandro Santilli <strk at kbt.io>
+	* [r16417] NEWS, liblwgeom/lwin_geojson.c: Do not include private
+	  header for json-c >= 0.13
+	  Patch by Björn Esser
+	  Closes #3942 for 2.4 branch
+	  (also fixes NEWS section corrupted by recent commit)
+2018-02-22 11:13  Darafei Praliaskouski <me at komzpa.net>
+	* [r16406] NEWS, postgis/lwgeom_box3d.c, regress/regress_expected,
+	  regress/sfcgal/regress_expected: Fix cast from box3d to geometry
+	  Patch by Matthias Bay
+	  Closes https://github.com/postgis/postgis/pull/214
+	  Closes #4020
+2018-02-21 14:31  Sandro Santilli <strk at kbt.io>
+	* [r16401] .gitlab-ci.yml: [gitlab-ci] Switch to PostgreSQL 9.6 and
+	  libjson-c-dev
+	  Fixes gitlab-ci build for 2.4, references #4023
+2018-02-21 09:05  Sandro Santilli <strk at kbt.io>
+	* [r16399] authors.git, authors.svn: Lowercase Algunenano
+	  All LDAP account names are lowercase
+2018-02-20 22:38  Regina Obe <lr at pcorp.us>
+	* [r16398] authors.git, authors.svn: Add Raúl Marín Rodríguez to
+	  developers list
+2018-02-20 22:35  Regina Obe <lr at pcorp.us>
+	* [r16397] ci/winnie/build_postgis.sh,
+	  backport regress changes from 2.5
+2018-01-26 14:55  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16362] NEWS, liblwgeom/lwpoly.c: lwpoly_construct_circle: Avoid
+	  division by zero (Raúl Marín Rodríguez)
+	  References #4003
+2018-01-26 12:47  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16361] NEWS, postgis/geography_btree.c: Avoid memory exhaustion
+	  when building a btree index (references #4004)
+	  From Edmund Horner
+2018-01-22 14:15  Sandro Santilli <strk at kbt.io>
+	* [r16358] NEWS, postgis/geography.sql.in: Set availability of
+	  support function for KNN index
+	  Fixes upgrade from 2.1 to 2.2+
+	  Closes #3978 in 2.4 branch (2.4.4)
+2018-01-22 12:35  Sandro Santilli <strk at kbt.io>
+	* [r16353] .drone.yml: [drone] Use trisquel2 image, test all pgsql
+	  versions and upgrades
+	  The new docker image also uses newer GEOS (3.6.2).
+	  References #3813 for 2.4 branch
+	  NOTE: could not use -Werror in this branch as it would fail
+2018-01-22 11:30  Sandro Santilli <strk at kbt.io>
+	* [r16350] regress/run_test.pl: backport run_test.pl fixes from
+	  trunk
+2018-01-21 07:12  Regina Obe <lr at pcorp.us>
+	* [r16347] ci/winnie/build_postgis.sh,
+	  change scripts back to versions of things to compile against
+	  (GDAL, PROJ, SCGAL, GEOS) being set at job level until we have
+	  the stop and start postgres in repo as well.
+2018-01-20 12:58  Sandro Santilli <strk at kbt.io>
+	* [r16346] ci/debbie/postgis_regress.sh: Have Debbie test all
+	  available upgrades
+	  References #2676 for 2.4 branch
+2018-01-18 21:46  Sandro Santilli <strk at kbt.io>
+	* [r16336] macros/pkg.m4: Forgot to add pkg.m4 macro in r16324
+	  See #3992
+2018-01-17 23:23  Regina Obe <lr at pcorp.us>
+	* [r16328] NEWS: Move PgSQL 11 support note to 2.4.4
+	  It was put in after 2.4.3 was already tagged and tarred.
+2018-01-16 20:54  Sandro Santilli <strk at kbt.io>
+	* [r16325] NEWS, configure.ac: Use PKG_PROG_PKG_CONFIG macro from
+	  pkg.m4 to detect pkg-config
+	  Patch by Bas Couwenberg
+	  Closes #3992 in 2.4 branch (for 2.4.4)
+2018-01-16 14:47  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16321] NEWS: Updates news re pg11 support
+2018-01-16 14:46  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16320] libpgcommon/lwgeom_pg.h, libpgcommon/lwgeom_transform.c,
+	  postgis/lwgeom_geos_prepared.c: Backport support for Pg11 to 2.4
+	  branch. Closes #3946
+2018-01-16 07:06  Regina Obe <lr at pcorp.us>
+	* [r16315] Version.config, ci/debbie/postgis_doc_translations.sh,
+	  ci/debbie/postgis_make_dist.sh,
+	  ci/debbie/postgis_release_docs.sh,
+	  extensions/upgradeable_versions.mk: flip version to 2.4.4dev, add
+	  2.4.3 to upgrade versions
+	  add timestamp to dev docs
+	  closes #3991 for PostGIS 2.4.4dev
+2018-01-15 21:38  Regina Obe <lr at pcorp.us>
+	* [r16305] ci/debbie/postgis_release_docs.sh: Get rid of SVN number
+	  and revise to not build local html except for trunk
+2018-01-15 20:47  Regina Obe <lr at pcorp.us>
+	* [r16301] HOWTO_RELEASE, Version.config: more clearifying notes on
+	  HOWTO_RELEASE
+	  change version to 2.4.3 in prep for tagging tomorrow or
+	  Wednesday.
+2018-01-15 00:50  Regina Obe <lr at pcorp.us>
+	* [r16299] ChangeLog, Version.config,
+	  ci/debbie/postgis_make_dist.sh: update ChangeLog
+	  flip Version.config to rc2
+	  revise make dist to output branch reading from
 2018-01-15 00:24  Regina Obe <lr at pcorp.us>
 	* [r16298] NEWS, configure.ac, doc/release_notes.xml:
Modified: branches/2.4/HOWTO_RELEASE
--- branches/2.4/HOWTO_RELEASE	2018-04-02 03:58:29 UTC (rev 16516)
+++ branches/2.4/HOWTO_RELEASE	2018-04-02 04:57:28 UTC (rev 16517)
@@ -1,6 +1,6 @@
 How to release
-Date: 2015-10-08
+Date: 2018-04-01
 Versioning Scheme
@@ -110,4 +110,4 @@
        This should automatically happen as a result of posting to PostGIS website since Planet PostGIS autotweets.
 - Update Trac and make old Milestone as completed
 - Push the revision number forward (see Versioning Scheme)
-- Remove the "dev" suffixed version from extensions/upgradeable_versions.mk
+- Remove the "dev" suffixed version from extensions/upgradeable_versions.mk
\ No newline at end of file
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS	2018-04-02 03:58:29 UTC (rev 16516)
+++ branches/2.4/NEWS	2018-04-02 04:57:28 UTC (rev 16517)
@@ -1,5 +1,5 @@
-PostGIS 2.4.4dev
-2018/04/DD
+PostGIS 2.4.4
+2018/04/08
  * Bug fixes *
   - #3055, [raster] ST_Clip() on a raster without band crashes the server
Modified: branches/2.4/README.postgis
--- branches/2.4/README.postgis	2018-04-02 03:58:29 UTC (rev 16516)
+++ branches/2.4/README.postgis	2018-04-02 04:57:28 UTC (rev 16517)
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 2.4.3dev
-:Date: 2017-xx-xx
+:Version: 2.4.4
+:Date: 2017-04-08
 :Website: http://postgis.net
 This distribution contains a module which implements GIS simple features, ties
@@ -202,7 +202,7 @@
 Upgrade PostGIS using the "ALTER EXTENSION" facility.
-  ALTER EXTENSION postgis UPDATE TO '2.2.0';
+  ALTER EXTENSION postgis UPDATE;
 USAGE
Modified: branches/2.4/Version.config
--- branches/2.4/Version.config	2018-04-02 03:58:29 UTC (rev 16516)
+++ branches/2.4/Version.config	2018-04-02 04:57:28 UTC (rev 16517)
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=2
 POSTGIS_MINOR_VERSION=4
-POSTGIS_MICRO_VERSION=4dev
+POSTGIS_MICRO_VERSION=4
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
Modified: branches/2.4/doc/release_notes.xml
--- branches/2.4/doc/release_notes.xml	2018-04-02 03:58:29 UTC (rev 16516)
+++ branches/2.4/doc/release_notes.xml	2018-04-02 04:57:28 UTC (rev 16517)
@@ -7,6 +7,38 @@
       <title>Release 2.4.3</title>
       <para>Release date: 2018/01/17</para>
       <para>This is a bug fix and performance improvement release.</para>
+      <simplesect><title>Bug Fixes</title>
+        <para>#3055, [raster] ST_Clip() on a raster without band crashes the server
+                  (Regina Obe)</para>
+        <para>#3942, geojson: Do not include private header for json-c >= 0.13
+                  (Björn Esser)</para>
+        <para>#3952, ST_Transform fails in parallel mode (Paul Ramsey)</para>
+        <para>#3978, Fix KNN when upgrading from 2.1 or older (Sandro Santilli)</para>
+        <para>#4003, lwpoly_construct_circle: Avoid division by zero (Raúl Marín Rodríguez)</para>
+        <para>#4004, Avoid memory exhaustion when building a btree index (Edmund Horner)</para>
+        <para>#4016, proj 5.0.0 support (Raúl Marín Rodríguez)</para>
+        <para>#4017, lwgeom lexer memory corruption (Peter E)</para>
+        <para>#4020, Casting from box3d to geometry now returns correctly connected
+                  PolyhedralSurface (Matthias Bay)</para>
+        <para>#4025, #4032 Incorrect answers for temporally "almost overlapping" ranges
+                  (Paul Ramsey, Darafei Praliaskouski)</para>
+        <para>#4052, schema qualify several functions in geography (Regina Obe)</para>
+        <para>#4055, ST_ClusterIntersecting drops SRID (Daniel Baston)</para>
+      </simplesect>
+      <simplesect><title>Enhancements</title>
+        <para>#3946, Compile support for PgSQL 11 (Paul Ramsey)</para>
+        <para>#3992, Use PKG_PROG_PKG_CONFIG macro from pkg.m4 to detect pkg-config
+                  (Bas Couwenberg)</para>
+        <para>#4044, Upgrade support for PgSQL 11 (Regina Obe)</para>
+      </simplesect>
+    </sect1>
+    <sect1>
+      <title>Release 2.4.3</title>
+      <para>Release date: 2018/01/17</para>
+      <para>This is a bug fix and performance improvement release.</para>
       <simplesect>
         <title>Bug Fixes and Enhancements</title>
         <para>#3713, Support encodings that happen to output a '\' character</para>
Modified: branches/2.4/extensions/upgradeable_versions.mk
--- branches/2.4/extensions/upgradeable_versions.mk	2018-04-02 03:58:29 UTC (rev 16516)
+++ branches/2.4/extensions/upgradeable_versions.mk	2018-04-02 04:57:28 UTC (rev 16517)
@@ -24,6 +24,7 @@
 	2.2.4 \
 	2.2.5 \
 	2.2.6 \
+	2.2.7 \
 	2.3.0 \
 	2.3.1 \
 	2.3.2 \
@@ -31,8 +32,10 @@
 	2.3.4 \
 	2.3.5 \
 	2.3.6 \
+	2.3.7 \
 	2.4.0 \
 	2.4.1 \
 	2.4.2 \
-	2.4.3
+	2.4.3 \
+	2.4.4dev
