[postgis-tickets] [PostGIS] #4062: Git lab ci need to be able to test 2.2 or turn off
PostGIS trac at osgeo.org
Sun Apr 1 23:45:01 PDT 2018
  Reporter:  robe       |      Owner:  strk
      Type:  defect     |     Status:  closed
  Priority:  medium     |  Milestone:  PostGIS 2.2.7
 Component:  buildbots  |    Version:  2.2.x
Resolution:  fixed      |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16518" 16518]:
 #!CommitTicketReference repository="" revision="16518"
 Copy Topology GML regression tests from 2.3 branch
 Hopefully fixes #4062 in 2.2 branch bringing in controlled order
 to make tests behave the same under different PostgreSQL versions
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4062#comment:2>
