[postgis-tickets] [PostGIS] #4068: Debbie chocking on sfcgal/CGAL
PostGIS trac at osgeo.org
Mon Apr 9 08:18:40 PDT 2018
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 2.4.5
Component:  buildbots  |    Version:  2.4.x
 Keywords:             |
 I assume this is caused by patch upgrades I did recently.
 My recent changes to 2.4 were just script changes for winnie so shouldn't
 caused this.
 Lately debbie is having problems.  It's showing just on 2.4, but expect it
 to show for 2.5 and 2.3 whenever next changes happen.
  -------------- Dependencies --------------
   GEOS config:
 /var/lib/jenkins/workspace/geos/rel-3.7.0devw64/bin/geos-config
   GEOS version:         3.7.0dev
   GDAL config:          /var/lib/jenkins/workspace/gdal/rel-2.1w64/bin
 /gdal-config
   GDAL version:         2.1.4
   SFCGAL config:        /usr/bin/sfcgal-config
   SFCGAL version:       1.3.1
   PostgreSQL config:
 /var/lib/jenkins/workspace/pg/rel/pg10w64/bin/pg_config
   PostgreSQL version:   PostgreSQL 10.3
   PROJ4 version:        50
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.9.4
   JSON-C support:       yes
   protobuf-c support:   yes
   PCRE support:         yes
   Perl:                 /usr/bin/perl
  --------------- Extensions ---------------
   PostGIS Raster:       enabled
   PostGIS Topology:     enabled
   SFCGAL support:       enabled
   Address Standardizer support:       enabled
  -------- Documentation Generation --------
   xsltproc:             /usr/bin/xsltproc
   xsl style sheets:     /usr/share/xml/docbook/stylesheet/docbook-xsl
   dblatex:              /usr/bin/dblatex
   convert:              /usr/bin/convert
   mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
 /lib/libgeos_c.so -lc -lm -Wl,-rpath
 -Wl,/var/lib/jenkins/workspace/pg/rel/pg10w64/lib -Wl,-rpath
 -Wl,/var/lib/jenkins/workspace/gdal/rel-2.1w64/lib -Wl,-rpath
 -Wl,/var/lib/jenkins/workspace/geos/rel-3.7.0devw64/lib
 //usr/lib/x86_64-linux-gnu/libSFCGAL.so.1: undefined reference to
 `operator>>(std::istream&, __mpz_struct*)'
 `CORE::BigFloatRep::operator new(unsigned long)'
 `CORE::BigFloatRep::toDouble() const'
 `CGAL::is_binary(std::basic_ios<char, std::char_traits<char> >&)'
 `CGAL::Random::Random(unsigned int)'
 `CGAL::ORIGIN'
 `operator<<(std::ostream&, __mpz_struct const*)'
 `CGAL::is_pretty(std::basic_ios<char, std::char_traits<char> >&)'
 `CGAL::assertion_fail(char const*, char const*, int, char const*)'
 `CORE::BigIntRep::operator delete(void*, unsigned long)'
 `CGAL::Random::Random()'
 `CGAL::NULL_VECTOR'
 `CORE::BigFloatRep::sqrt(CORE::BigFloatRep const&, CORE::extLong const&)'
 `CORE::BigFloatRep::operator delete(void*, unsigned long)'
 `CGAL::File_header_OFF::File_header_OFF(bool, bool, bool, bool)'
 `CGAL::get_mode(std::basic_ios<char, std::char_traits<char> >&)'
 `CORE::BigIntRep::operator new(unsigned long)'
 `CORE::defBFsqrtAbsPrec'
 `CORE::BigFloatRep::BigFloatRep(double)'
 `CGAL::File_writer_OFF::write_header(std::ostream&, unsigned long,
 unsigned long, unsigned long, bool)'
 collect2: error: ld returned 1 exit status
 make[2]: *** [Makefile:85: raster2pgsql] Error 1
 make[2]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/2.4/raster/loader'
 make[1]: *** [Makefile:31: rtloader] Error 2
 make[1]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/2.4/raster'
 make: *** [GNUmakefile:16: all] Error 1
 Build step 'Execute shell' marked build as failure
 An attempt to send an e-mail to empty list of recipients, ignored.
 I suspect something to do with CGAL perhaps incompatible with the SFCGAL
 installed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4068>
