[postgis-tickets] r16537 - Disable sfcgal in make dist and regress testing until sfcgal compile issue
Regina Obe lr at pcorp.us
Mon Apr 9 09:06:01 PDT 2018
Author: robe
Date: 2018-04-09 21:06:01 -0700 (Mon, 09 Apr 2018)
New Revision: 16537
   trunk/ci/debbie/postgis_make_dist.sh
   trunk/ci/debbie/postgis_regress.sh
 for CGAL 4.11 / SFCGAL 1.3.3 against PostGIS is fixed
References #4068 for PostGIS 2.5
Modified: trunk/ci/debbie/postgis_make_dist.sh
--- trunk/ci/debbie/postgis_make_dist.sh	2018-04-10 02:34:23 UTC (rev 16536)
+++ trunk/ci/debbie/postgis_make_dist.sh	2018-04-10 04:06:01 UTC (rev 16537)
@@ -19,7 +19,7 @@
 POSTGIS_MINOR_VERSION=`grep ^POSTGIS_MINOR_VERSION Version.config | cut -d= -f2`
 POSTGIS_MICRO_VERSION=`grep ^POSTGIS_MICRO_VERSION Version.config | cut -d= -f2`
-export CONFIGURE_ARGS="--with-pgconfig=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}/bin/pg_config --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config --with-sfcgal=/usr/bin/sfcgal-config --prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}"
+export CONFIGURE_ARGS="--with-pgconfig=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}/bin/pg_config --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config --prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}"
 #override the checkout folder used for building tar ball
 export newoutdir="postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}"
Modified: trunk/ci/debbie/postgis_regress.sh
--- trunk/ci/debbie/postgis_regress.sh	2018-04-10 02:34:23 UTC (rev 16536)
+++ trunk/ci/debbie/postgis_regress.sh	2018-04-10 04:06:01 UTC (rev 16537)
@@ -61,7 +61,7 @@
 ./configure \
     --with-pgconfig=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}/bin/pg_config \
     --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
-    --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config --with-sfcgal=/usr/bin/sfcgal-config \
+    --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config \
     --without-interrupt-tests \
 make clean
