[postgis-tickets] [PostGIS] #4067: DirectFunctionCall* crash when called directly from C code
PostGIS trac at osgeo.org
Mon Apr 16 10:28:28 PDT 2018
  Reporter:  ezimanyi  |      Owner:  pramsey
      Type:  defect    |     Status:  closed
  Priority:  medium    |  Milestone:  PostGIS 2.4.5
 Component:  postgis   |    Version:  2.4.x
Resolution:  fixed     |   Keywords:
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16543" 16543]:
 #!CommitTicketReference repository="" revision="16543"
 Guard against lookup failure, to avoid segfault in internally called case
 (closes #4067)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4067#comment:2>
