[postgis-tickets] [PostGIS] #4072: ST_OffsetCurve fails on very specific inputs
PostGIS trac at osgeo.org
Fri Apr 20 06:47:53 PDT 2018
 Reporter:  simonseyock  |      Owner:  pramsey
     Type:  defect       |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS GEOS
Component:  postgis      |    Version:  2.3.x
 Keywords:               |
 The following command fails:
 SELECT ST_OffsetCurve(ST_GeomFromText('LINESTRING(362194.505
 5649993.044,362197.451 5649994.125,362194.624 5650001.876,362189.684
 5650000.114,362192.542 5649992.324,362194.505 5649993.044)', 25832),
 -0.045, 'join=mitre');
 with the error:
 FEHLER: GEOSOffsetCurve: TopologyException: assigned depths do not match
 at 362194.48950385087 5649993.0862477142
 SQL Status:XX000
 I am using:
 POSTGIS="2.3.2 r15302" GEOS="3.6.1-CAPI-1.10.1 r4317" PROJ="Rel. 4.9.1, 04
 March 2015" GDAL="GDAL 2.1.3, released 2017/20/01" LIBXML="2.7.8"
 LIBJSON="0.12" RASTER
 I also tested it with:
 POSTGIS="2.3.3 r15473" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
 March 2012" GDAL="GDAL 1.10.1, released 2013/08/26" LIBXML="2.9.1"
 LIBJSON="0.11.99" RASTER
 Note that the first and last coordinates of the linestring are the same.
 If the first or last coordinate or both are changed the error does not
 occur. Also if another distance than -0.045 is used the error does not
 occur.
 This error might be somewhat related to #2496, the fix however is not
 applicable as the bug does appear with newer versiosn of GEOS.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4072>
