[postgis-tickets] [PostGIS] #4074: Disable interrupt tests by default for PostGIS 2.3
PostGIS trac at osgeo.org
Tue Apr 24 02:28:03 PDT 2018
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 2.3.8
 Component:  postgis  |    Version:  2.3.x
Resolution:  fixed    |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16551" 16551]:
 #!CommitTicketReference repository="" revision="16551"
 Disable interrupt tests by default, now requires --with-interrupt-tests to
 turn on.
 This is to quiet false alarms which often happen on a busy box
 Closes #4074
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4074#comment:3>
