[postgis-tickets] r16554 - [doc] reword ST_QuantizeCoordinates doc
Darafei komzpa at gmail.com
Tue Apr 24 07:39:40 PDT 2018
Author: komzpa
Date: 2018-04-24 07:39:39 -0700 (Tue, 24 Apr 2018)
New Revision: 16554
   trunk/doc/reference_misc.xml
Modified: trunk/doc/reference_misc.xml
--- trunk/doc/reference_misc.xml	2018-04-24 13:26:49 UTC (rev 16553)
+++ trunk/doc/reference_misc.xml	2018-04-24 14:39:39 UTC (rev 16554)
@@ -747,8 +747,8 @@
 				but will have improved compressiblity. This can result in a
 				significant disk usage reduction provided that the geometry column
 				is using a <ulink
-					url="https://www.postgresql.org/docs/current/static/storage-toast.html#STORAGE-TOAST-ONDISK">
-					compressible storage type</ulink>. The function allows
+				url="https://www.postgresql.org/docs/current/static/storage-toast.html#STORAGE-TOAST-ONDISK">
+				compressible storage type</ulink>. The function allows
 				specification of a different number of digits after the decimal
 				point in each dimension; unspecified dimensions are assumed to have
 				the precsion of the <code>x</code> dimension. Negative digits are
@@ -761,8 +761,8 @@
 				independent of the geometry that contains those coordinates and the
 				relative position of those coordinates within the geometry. As a result,
 				existing topological relationships between geometries are unaffected
-				by use of this function. The function will not produce invalid geometry
-				unless it is called with a number of digits lower than the intrinsic
+				by use of this function. The function may produce invalid geometry
+				when it is called with a number of digits lower than the intrinsic
 				precision of the geometry.
 			</para>
 			<para>Availability: 2.5.0</para>
@@ -790,10 +790,11 @@
 				point numbers closest to 100.123456000000, 100.123456000001, and
 				100.123456432199. All are equally valid, in that
 				<code>ST_AsText(geom, 6)</code> will return the same result with
-				any of these inputs. Because we can set these bits to whatever we
-				like, <code>ST_QuantizeCoordinates</code> sets the 22 insignificant
-				bits to zero because a block of 22 zeros is easily (and automatically)
-				compressed by PostgreSQL's built-in compression algorithm.
+				any of these inputs. As we can set these bits to any value,
+				<code>ST_QuantizeCoordinates</code> sets the 22 insignificant
+				bits to zero. For a long coordinate sequence this creates a
+				pattern of blocks of consecutive zeros that is compressed
+				by PostgreSQL more effeciently.
 			</para>
 			<note>
