[postgis-tickets] [PostGIS] #4266: Freebsd machines don't have CUnit installed
PostGIS trac at osgeo.org
Tue Dec 4 00:19:26 PST 2018
 Reporter:  Algunenano  |      Owner:  robe
     Type:  defect      |     Status:  new
 Priority:  low         |  Milestone:  PostGIS 3.0.0
Component:  buildbots   |    Version:  trunk
 Keywords:              |
 Neither Bessie nor Bessie32 have CUnit installed:
 00:20:08 checking CUnit/CUnit.h usability... no
 00:20:08 checking CUnit/CUnit.h presence... no
 00:20:08 checking for CUnit/CUnit.h... no
 00:20:08 configure: WARNING: could not locate CUnit required for unit
 tests
 00:25:25 WARNING:
 00:25:25
 00:25:25 configure was unable to find CUnit which is required for unit
 testing.
 00:25:25 In order to enable unit testing, you must install CUnit and then
 re-run configure.
 00:25:25
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4266>
