[postgis-tickets] r17101 - Remove tickets.sql for SFCGAL.
Darafei komzpa at gmail.com
Tue Dec 4 12:03:09 PST 2018
Author: komzpa
Date: 2018-12-04 12:03:09 -0800 (Tue, 04 Dec 2018)
New Revision: 17101
Removed:
   trunk/regress/sfcgal/tickets.sql
   trunk/regress/sfcgal/tickets_expected
   trunk/regress/sfcgal/Makefile.in
They're same as geos now anyway, no need to test twice.
References #4258
Modified: trunk/regress/sfcgal/Makefile.in
--- trunk/regress/sfcgal/Makefile.in	2018-12-04 19:39:28 UTC (rev 17100)
+++ trunk/regress/sfcgal/Makefile.in	2018-12-04 20:03:09 UTC (rev 17101)
@@ -40,7 +40,6 @@
 		regress_ogc_prep.sql \
 		regress_ogc.sql \
 		regress.sql \
-		tickets.sql \
 		concave_hull.sql \
 		wmsservers.sql \
 		approximatemedialaxis.sql
Deleted: trunk/regress/sfcgal/tickets.sql
--- trunk/regress/sfcgal/tickets.sql	2018-12-04 19:39:28 UTC (rev 17100)
+++ trunk/regress/sfcgal/tickets.sql	2018-12-04 20:03:09 UTC (rev 17101)
@@ -1,816 +0,0 @@
--- Regression tests that were filed as cases in bug tickets,
--- referenced by bug number for historical interest.
-SET postgis.backend = 'sfcgal';
--- NOTE: some tests _require_ spatial_ref_sys entries.
--- In particular, the GML output ones want auth_name and auth_srid too,
--- so we provide one for EPSG:4326
-DELETE FROM spatial_ref_sys;
-INSERT INTO spatial_ref_sys ( srid, proj4text ) VALUES ( 32611, '+proj=utm +zone=11 +ellps=WGS84 +datum=WGS84 +units=m +no_defs' );
-INSERT INTO spatial_ref_sys ( auth_name, auth_srid, srid, proj4text ) VALUES ( 'EPSG', 4326, 4326, '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs' );
-INSERT INTO spatial_ref_sys ( srid, proj4text ) VALUES ( 32602, '+proj=utm +zone=2 +ellps=WGS84 +datum=WGS84 +units=m +no_defs ' );
-INSERT INTO spatial_ref_sys ( srid, proj4text ) VALUES ( 32702, '+proj=utm +zone=2 +south +ellps=WGS84 +datum=WGS84 +units=m +no_defs ' );
-INSERT INTO spatial_ref_sys ( srid, proj4text ) VALUES ( 3395, '+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs ' );
-INSERT INTO spatial_ref_sys (srid,proj4text) VALUES (32707,'+proj=utm +zone=7 +south +ellps=WGS84 +datum=WGS84 +units=m +no_defs ');
--- #2 --
-SELECT '#2', ST_AsText(ST_Union(g)) FROM
-( VALUES
-('SRID=4326;MULTIPOLYGON(((1 1,1 2,2 2,2 1,1 1)))'),
-('SRID=4326;MULTIPOLYGON(((2 1,3 1,3 2,2 2,2 1)))')
-) AS v(g);
--- #11 --
-SELECT '#11', round(ST_Distance (a.g, ST_Intersection(b.g, a.g))) AS distance
-FROM (SELECT '01020000000200000050E8303FC2E85141B017CFC05A825541000000E0C0E85141000000205C825541'::geometry AS g) a,
-	 (SELECT 'LINESTRING(4694792.35840419 5638508.89950758,4694793.20840419 5638506.34950758)'::geometry AS g) b;
--- #21 --
-SELECT '#21', ST_AsEWKT(ST_Locate_Along_Measure(g, 4566)) FROM
-( VALUES
-(ST_GeomFromEWKT('SRID=31293;LINESTRINGM( 6193.76 5337404.95 4519, 6220.13 5337367.145 4566, 6240.889 5337337.383 4603 )'))
-) AS v(g);
--- #22 --
-SELECT ST_Within(g, 'POLYGON((0 0,10 0,20 10,10 20,0 20,-10 10,0 0))') FROM
-(VALUES
-('POLYGON((4 9,6 9,6 11,4 11,4 9))')
-) AS v(g);
--- #33 --
-CREATE TABLE road_pg (ID INTEGER, NAME VARCHAR(32));
-SELECT '#33', AddGeometryColumn( '', 'public', 'road_pg','roads_geom', 330000, 'POINT', 2 );
-DROP TABLE road_pg;
--- #44 --
-SELECT '#44', ST_Relate(g1, g2, 'T12101212'), ST_Relate(g1, g2, 't12101212') FROM
-(VALUES
-('POLYGON((0 0, 2 0, 2 2, 0 2, 0 0))', 'POLYGON((1 1, 3 1, 3 3, 1 3, 1 1))')
-) AS v(g1, g2);
--- #58 --
-SELECT '#58', round(ST_xmin(g)),round(ST_ymin(g)),round(ST_xmax(g)),round(ST_ymax(g)) FROM (SELECT ST_Envelope('CIRCULARSTRING(220268.439465645 150415.359530563,220227.333322076 150505.561285879,220227.353105332 150406.434743975)'::geometry) as g)  AS foo;
--- #65 --
-SELECT '#65', ST_AsGML(ST_GeometryFromText('CURVEPOLYGON(CIRCULARSTRING(4 2,3 -1.0,1 -1,-1.0 4,4 2))'));
--- #66 --
-SELECT '#66', ST_AsText((ST_Dump(ST_GeomFromEWKT('CIRCULARSTRING(0 0,1 1,2 2)'))).geom);
--- #68 --
-SELECT '#68a', ST_AsText(ST_ShiftLongitude(ST_GeomFromText('MULTIPOINT(1 3, 4 5)')));
-SELECT '#68b', ST_AsText(ST_ShiftLongitude(ST_GeomFromText('CIRCULARSTRING(1 3, 4 5, 6 7)')));
--- #69 --
-SELECT '#69', ST_AsText(ST_Translate(ST_GeomFromText('CIRCULARSTRING(220268 150415,220227 150505,220227 150406)'),1,2));
--- #70 --
-SELECT '#70', ST_NPoints(ST_LinetoCurve(ST_Buffer('POINT(1 2)',3)));
--- #73 --
-SELECT '#73', ST_AsText(ST_ForceCollection(ST_GeomFromEWKT('CIRCULARSTRING(1 1, 2 3, 4 5, 6 7, 5 6)')));
--- #80 --
-SELECT '#80', ST_AsText(ST_Multi('MULTILINESTRING((0 0,1 1))'));
--- #83 --
-SELECT '#83', ST_AsText(ST_Multi(ST_GeomFromText('CIRCULARSTRING(220268 150415,220227 150505,220227 150406)')));
--- #85 --
-SELECT '#85', ST_Distance(ST_GeomFromText('CIRCULARSTRING(220268 150415,220227 150505,220227 150406)'), ST_Point(220268, 150415));
--- #112 --
-SELECT '#112', ST_AsText(ST_CurveToLine('GEOMETRYCOLLECTION(POINT(-10 50))'::geometry));
--- #113 --
-SELECT '#113', ST_Locate_Along_Measure('LINESTRING(0 0 0, 1 1 1)', 0.5);
--- #116 --
-SELECT '#116', ST_AsText('010300000000000000');
--- #122 --
-SELECT '#122', ST_AsText(ST_SnapToGrid(ST_GeomFromText('CIRCULARSTRING(220268 150415,220227 150505,220227 150406)'), 0.1));
--- #124 --
-SELECT '#124a', ST_AsText(ST_GeomFromEWKT('COMPOUNDCURVE(CIRCULARSTRING(0 0,1 1,1 0),(1 0,30 5),CIRCULARSTRING(30 5,34 56,67 89))'));
-SELECT '#124b', ST_AsText(ST_GeomFromEWKT('COMPOUNDCURVE(CIRCULARSTRING(0 0,1 1,1 0),(1 0,30 6),CIRCULARSTRING(30 5,34 56,67 89))'));
--- #145 --
-SELECT '#145a', ST_AsText(ST_Buffer(ST_GeomFromText('LINESTRING(-116.93414544665981 34.16033385105459,-116.87777514700957 34.10831080544884,-116.86972224705954 34.086748622072776,-116.9327074288116 34.08458099517253,-117.00216369088065 34.130329331330216,-117.00216369088065 34.130329331330216)', 4326), 0));
-SELECT '#145b', ST_Area(ST_Buffer(ST_GeomFromText('LINESTRING(-116.93414544665981 34.16033385105459,-116.87777514700957 34.10831080544884,-116.86972224705954 34.086748622072776,-116.9327074288116 34.08458099517253,-117.00216369088065 34.130329331330216,-117.00216369088065 34.130329331330216)', 4326), 0));
--- #146 --
-SELECT '#146', ST_Distance(g1,g2), ST_Dwithin(g1,g2,0.01), ST_AsEWKT(g2) FROM (SELECT ST_geomFromEWKT('LINESTRING(1 2, 2 4)') As g1, ST_Collect(ST_GeomFromEWKT('LINESTRING(0 0, -1 -1)'), ST_GeomFromEWKT('MULTIPOINT(1 2,2 3)')) As g2) As foo;
--- #156 --
-SELECT '#156', ST_AsEWKT('0106000000010000000103000000010000000700000024213D12AA7BFD40945FF42576511941676A32F9017BFD40B1D67BEA7E511941C3E3C640DB7DFD4026CE38F4EE531941C91289C5A7EFD40017B8518E3531941646F1599AB7DFD409627F1F0AE521941355EBA49547CFD407B14AEC74652194123213D12AA7BFD40945FF42576511941');
--- #157 --
-SELECT
-	'#157',
-	ST_GeometryType(g) As newname,
-	GeometryType(g) as oldname
-FROM ( VALUES
-	(ST_GeomFromText('POLYGON((-0.25 -1.25,-0.25 1.25,2.5 1.25,2.5 -1.25,-0.25 -1.25), (2.25 0,1.25 1,1.25 -1,2.25 0),(1 -1,1 1,0 0,1 -1))') ),
-	( ST_Point(1,2) ),
-	( ST_Buffer(ST_Point(1,2), 3) ),
-	( ST_LineToCurve(ST_Buffer(ST_Point(1,2), 3)) ) ,
-	( ST_LineToCurve(ST_Boundary(ST_Buffer(ST_Point(1,2), 3))) )
-	) AS v(g);
--- #168 --
-SELECT '#168', ST_NPoints(g), ST_AsText(g), ST_isValidReason(g)
-FROM ( VALUES
-('01060000C00100000001030000C00100000003000000E3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFF'::geometry)
-) AS v(g);
--- #175 --
-SELECT '#175', ST_AsEWKT(ST_GeomFromEWKT('SRID=26915;POINT(482020 4984378.)'));
--- #178 --
-SELECT '#178a', ST_XMin(ST_MakeBox2D(ST_Point(5, 5), ST_Point(0, 0)));
-SELECT '#178b', ST_XMax(ST_MakeBox2D(ST_Point(5, 5), ST_Point(0, 0)));
--- #179 --
-SELECT '#179a', ST_MakeLine(ARRAY[NULL,NULL,NULL,NULL]);
-SELECT '#179b', ST_MakeLine(ARRAY[NULL,NULL,NULL,NULL]);
--- #183 --
-SELECT '#183', ST_AsText(ST_SnapToGrid(ST_LineToCurve(ST_LineMerge(ST_Collect(ST_CurveToLine(ST_GeomFromEWKT('CIRCULARSTRING(0 0, 1 1, 1 0)')),ST_GeomFromEWKT('LINESTRING(1 0, 0 1)') ))), 1E-10));
--- #210 --
-SELECT '#210a', ST_Union(ARRAY[NULL,NULL,NULL,NULL]) ;
-SELECT '#210b', ST_MakeLine(ARRAY[NULL,NULL,NULL,NULL]) ;
--- #213 --
-SELECT '#213', round(ST_Perimeter(ST_CurveToLine(ST_GeomFromEWKT('CURVEPOLYGON(COMPOUNDCURVE(CIRCULARSTRING(0 0,2 0, 2 1, 2 3, 4 3),(4 3, 4 5, 1 4, 0 0)))'))));
--- #234 --
-SELECT '#234', ST_AsText(ST_GeomFromText('COMPOUNDCURVE( (0 0,1 1) )'));
--- #239 --
---SELECT '#239', ST_AsSVG('010700002031BF0D0000000000');
--- #241 --
-CREATE TABLE c ( the_geom GEOMETRY);
-INSERT INTO c SELECT ST_MakeLine(ST_Point(-10,40),ST_Point(40,-10)) As the_geom;
-SELECT '#241', sum(ST_LineCrossingDirection(the_geom, ST_GeomFromText('LINESTRING(1 2,3 4)'))) FROM c;
-DROP TABLE c;
--- #254 --
-SELECT '#254', ST_AsText(ST_Segmentize(ST_GeomFromText('GEOMETRYCOLLECTION EMPTY'), 0.5));
--- #259 --
-SELECT '#259', ST_Distance(ST_GeographyFromText('SRID=4326;POLYGON EMPTY'), ST_GeographyFromText('SRID=4326;POINT(1 2)'));
--- #260 --
-SELECT '#260', round(ST_Distance(ST_GeographyFromText('SRID=4326;POINT(-10 40)'), ST_GeographyFromText('SRID=4326;POINT(-10 55)')));
--- #261 --
-SELECT '#261', ST_Distance(ST_GeographyFromText('SRID=4326;POINT(-71.0325022849392 42.3793285830812)'),ST_GeographyFromText('SRID=4326;POLYGON((-71.0325022849392 42.3793285830812,-71.0325745928559 42.3793012556699,-71.0326708728343 42.3794450989722,-71.0326045866257 42.3794706688942,-71.0325022849392 42.3793285830812))'));
--- #262 --
-SELECT '#262', ST_AsText(pt.the_geog) As wkt_pt, ST_Covers(poly.the_geog, pt.the_geog) As geog,
-	ST_Covers(
-		ST_Transform(CAST(poly.the_geog As geometry),32611),
-		ST_Transform(CAST(pt.the_geog As geometry),32611)) As utm,
-	ST_Covers(
-		CAST(poly.the_geog As geometry),
-		CAST(pt.the_geog As geometry)
-	) As pca
-FROM (SELECT ST_GeographyFromText('SRID=4326;POLYGON((-119.5434 34.9438,-119.5437 34.9445,-119.5452 34.9442,-119.5434 34.9438))') As the_geog)
-	As poly
-    CROSS JOIN
-	(VALUES
-		( ST_GeographyFromText('SRID=4326;POINT(-119.5434 34.9438)') ) ,
-		( ST_GeographyFromText('SRID=4326;POINT(-119.5452 34.9442)') ) ,
-		( ST_GeographyFromText('SRID=4326;POINT(-119.5434 34.9438)') ),
-		( ST_GeographyFromText('SRID=4326;POINT(-119.5438 34.9443)')  )
-	As pt(the_geog);
--- #263 --
-SELECT '#263', ST_AsEWKT(geometry(geography(pt.the_geom))) As wkt,
-	ST_Covers(
-		ST_Transform(poly.the_geom,32611),
-		ST_Transform(pt.the_geom,32611)) As utm,
-	ST_Covers(
-		poly.the_geom,
-		pt.the_geom)
-	 As pca,
-	ST_Covers(geometry(geography(poly.the_geom)),
-		geometry(geography(pt.the_geom))) As gm_to_gg_gm_pca
-FROM (SELECT ST_GeomFromEWKT('SRID=4326;POLYGON((-119.5434 34.9438,-119.5437 34.9445,-119.5452 34.9442,-119.5434 34.9438))') As the_geom)
-	As poly
-    CROSS JOIN
-	(VALUES
-		( ST_GeomFromEWKT('SRID=4326;POINT(-119.5434 34.9438)') ) ,
-		( ST_GeomFromEWKT('SRID=4326;POINT(-119.5452 34.9442)') ) ,
-		( ST_GeomFromEWKT('SRID=4326;POINT(-119.5434 34.9438)') ),
-		( ST_GeomFromEWKT('SRID=4326;POINT(-119.5438 34.9443)')  )
-	As pt(the_geom);
--- #271 --
-SELECT '#271', ST_Covers(
-'POLYGON((-9.123456789 50,51 -11.123456789,-10.123456789 50,-9.123456789 50))'::geography,
-'POINT(-10.123456789 50)'::geography
--- #272 --
-SELECT '#272', ST_LineCrossingDirection(foo.line1, foo.line2) As l1_cross_l2 ,
-    ST_LineCrossingDirection(foo.line2, foo.line1) As l2_cross_l1
-FROM (SELECT
-    ST_GeomFromText('LINESTRING(25 169,89 114,40 70,86 43)') As line1, ST_GeomFromText('LINESTRING(2.99 90.16,71 74,20 140,171 154)') As line2 ) As foo;
--- #277 --
-SELECT '#277', ST_AsGML(2, ST_GeomFromText('POINT(1 1e308)'));
--- #299 --
-SELECT '#299', round(ST_Y(geometry(ST_Intersection(ST_GeographyFromText('POINT(1.2456 2)'), ST_GeographyFromText('POINT(1.2456 2)')))));
--- #304 --
-SELECT '#304';
-CREATE OR REPLACE FUNCTION utmzone(geometry)
-  RETURNS integer AS
-$BODY$
-DECLARE
-    geomgeog geometry;
-    zone int;
-    pref int;
-BEGIN
-    geomgeog:= ST_Transform($1,4326);
-    IF (ST_Y(geomgeog))>0 THEN
-       pref:=32600;
-    ELSE
-       pref:=32700;
-    END IF;
-    zone:=floor((ST_X(geomgeog)+180)/6)+1;
-    IF ( zone > 60 ) THEN zone := 60; END IF;
-    RETURN zone+pref;
-END;
-$BODY$ LANGUAGE 'plpgsql' IMMUTABLE
-  COST 100;
-CREATE TABLE utm_dots ( the_geog geography, utm_srid integer);
-INSERT INTO utm_dots SELECT geography(ST_SetSRID(ST_Point(i*10,j*10),4326)) As the_geog, utmzone(ST_SetSRID(ST_Point(i*10,j*10),4326)) As utm_srid FROM generate_series(-17,17) As i CROSS JOIN generate_series(-8,8) As j;
-SELECT ST_AsText(the_geog) as the_pt,
-       utm_srid,
-       ST_Area(ST_Buffer(the_geog,10)) As the_area,
-       ST_Area(geography(ST_Transform(ST_Buffer(ST_Transform(geometry(the_geog),utm_srid),10),4326))) As geog_utm_area
-FROM utm_dots
-WHERE ST_Area(ST_Buffer(the_geog,10)) NOT between 307 and 315
-LIMIT 10;
-SELECT '#304.a', Count(*) FROM utm_dots WHERE ST_DWithin(the_geog, 'POINT(0 0)'::geography, 3000000);
-CREATE INDEX utm_dots_gix ON utm_dots USING GIST (the_geog);
-SELECT '#304.b', Count(*) FROM utm_dots WHERE ST_DWithin(the_geog, 'POINT(0 0)'::geography, 300000);
-DROP FUNCTION utmzone(geometry);
-DROP TABLE utm_dots;
--- #408 --
-SELECT '#408', substring(st_isvalidreason('0105000020E0670000010000000102000020E06700000100000016DA52BA62A04141FFF3AD290B735241') from E'.*\\[');
-SELECT '#408.1', st_isvalid('01050000000100000001020000000100000000000000000000000000000000000000');
-SELECT '#408.2', st_isvalidreason('01020000000100000000000000000000000000000000000000');
-SELECT '#408.3', st_isvalid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');
-SELECT '#408.4', st_isvalidreason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');
--- #457 --
-SELECT '#457.1', st_astext(st_collectionExtract('POINT(0 0)', 1));
-SELECT '#457.2', st_astext(st_collectionExtract('POINT(0 0)', 2));
-SELECT '#457.3', st_astext(st_collectionExtract('POINT(0 0)', 3));
-SELECT '#457.4', st_astext(st_collectionExtract('LINESTRING(0 0, 1 1)', 1));
-SELECT '#457.5', st_astext(st_collectionExtract('LINESTRING(0 0, 1 1)', 2));
-SELECT '#457.6', st_astext(st_collectionExtract('LINESTRING(0 0, 1 1)', 3));
-SELECT '#457.7', st_astext(st_collectionExtract('POLYGON((0 0, 1 0, 1 1, 0 1, 0 0))', 1));
-SELECT '#457.8', st_astext(st_collectionExtract('POLYGON((0 0, 1 0, 1 1, 0 1, 0 0))', 2));
-SELECT '#457.9', st_astext(st_collectionExtract('POLYGON((0 0, 1 0, 1 1, 0 1, 0 0))', 3));
--- #835 --
-SELECT '#835.1', st_astext(st_collectionExtract('POLYGON EMPTY', 1));
-SELECT '#835.2', st_astext(st_collectionExtract('POLYGON EMPTY', 2));
-SELECT '#835.3', st_astext(st_collectionExtract('POLYGON EMPTY', 3));
-SELECT '#835.4', st_astext(st_collectionExtract('LINESTRING EMPTY', 1));
-SELECT '#835.5', st_astext(st_collectionExtract('LINESTRING EMPTY', 2));
-SELECT '#835.6', st_astext(st_collectionExtract('LINESTRING EMPTY', 3));
-SELECT '#835.7', st_astext(st_collectionExtract('POINT EMPTY', 1));
-SELECT '#835.8', st_astext(st_collectionExtract('POINT EMPTY', 2));
-SELECT '#835.9', st_astext(st_collectionExtract('POINT EMPTY', 3));
-SELECT '#835.10', st_astext(st_collectionExtract('GEOMETRYCOLLECTION EMPTY', 1));
-SELECT '#835.11', st_astext(st_collectionExtract('GEOMETRYCOLLECTION EMPTY', 2));
-SELECT '#835.12', st_astext(st_collectionExtract('GEOMETRYCOLLECTION EMPTY', 3));
--- #650 --
-SELECT '#650', ST_AsText(ST_Collect(ARRAY[ST_MakePoint(0,0), ST_MakePoint(1,1), null, ST_MakePoint(2,2)]));
--- #662 --
---SELECT '#662', ST_MakePolygon(ST_AddPoint(ST_AddPoint(ST_MakeLine(ST_SetSRID(ST_MakePointM(i+m,j,m),4326),ST_SetSRID(ST_MakePointM(j+m,i-m,m),4326)),ST_SetSRID(ST_MakePointM(i,j,m),4326)),ST_SetSRID(ST_MakePointM(i+m,j,m),4326))) As the_geom FROM generate_series(-10,50,20) As i CROSS JOIN generate_series(50,70, 20) As j CROSS JOIN generate_series(1,2) As m ORDER BY i, j, m, i*j*m LIMIT 1;
--- #667 --
-WITH vs AS (SELECT c[1]::int AS major, c[2]::int AS minor, c[3]::int AS patch
-    FROM (SELECT regexp_split_to_array(postgis_sfcgal_version(),'\.') AS c) AS r )
-SELECT '#667',
-CASE WHEN vs.major >= 1 AND vs.minor >= 0 AND vs.patch >=5 THEN
-ST_AsEWKT(ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j)))
-ELSE
-'SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 39.9999999999999,30 40))'
-END As the_geom
-FROM vs, generate_series(-10,50,10) As i CROSS JOIN generate_series(40,70, 20) As j ORDER BY i, j, i*j LIMIT 1;
--- #677 --
-SELECT '#677',round(ST_DistanceSpheroid(ST_GeomFromEWKT('MULTIPOLYGON(((-10 40,-10 55,-10 70,5 40,-10 40)))'), ST_GeomFromEWKT('MULTIPOINT(20 40,20 55,20 70,35 40,35 55,35 70,50 40,50 55,50 70)'), 'SPHEROID["GRS_1980",6378137,298.257222101]')) As result;
--- #680 --
-SELECT '#680', encode(ST_AsBinary(geography(foo1.the_geom), 'NDR'),'hex') As result FROM ((SELECT ST_SetSRID(ST_MakePointM(i,j,m),4326) As the_geom FROM generate_series(-10,50,10) As i CROSS JOIN generate_series(50,70, 20) AS j CROSS JOIN generate_series(1,2) As m ORDER BY i, j, i*j*m)) As foo1 LIMIT 1;
--- #681 --
-SELECT '#681a', ST_AsGML(ST_GeomFromText('POINT EMPTY', 4326));
-SELECT '#681b', ST_AsGML(ST_GeomFromText('POLYGON EMPTY', 4326));
-SELECT '#681c', ST_AsGML(ST_GeomFromText('LINESTRING EMPTY', 4326));
-SELECT '#681d', ST_AsGML(ST_GeomFromText('MULTIPOINT EMPTY', 4326));
-SELECT '#681e', ST_AsGML(ST_GeomFromText('MULTILINESTRING EMPTY', 4326));
-SELECT '#681f', ST_AsGML(ST_GeomFromText('MULTIPOLYGON EMPTY', 4326));
-SELECT '#681g', ST_AsGML(ST_GeomFromText('GEOMETRYCOLLECTION EMPTY', 4326));
--- #682 --
-SELECT '#682', ST_AsText(ST_Buffer(ST_GeomFromText('POLYGON EMPTY',4326) , 0.5));
--- #683 --
-SELECT '#683', ST_AsText(ST_BuildArea(ST_GeomFromText('POINT EMPTY',4326)));
--- #684,#2109 --
-SELECT '#684,#2109', ST_AsEWKT(ST_Centroid(ST_GeomFromText('POLYGON EMPTY',4326)));
-SELECT '#2109', ST_AsEWKT(ST_Centroid(ST_GeomFromText('MULTILINESTRING ZM EMPTY',3395)));
--- #685 --
-SELECT '#685', ST_AsText(ST_ConvexHull(ST_GeomFromText('POLYGON EMPTY',4326)));
--- #686 --
-SELECT '#686', St_AsText(ST_COLLECT(ST_GeomFromText('POLYGON EMPTY',4326),ST_GeomFromText('TRIANGLE EMPTY',4326)));
--- #687 --
-SELECT '#687', ST_DFullyWithin(ST_GeomFromText('LINESTRING(-10 50,50 -10)',4326), ST_GeomFromText('POLYGON EMPTY',4326),5);
--- #689 --
-SELECT '#689', ST_CoveredBy(ST_GeomFromText('POLYGON EMPTY'), ST_GeomFromText('LINESTRING(-10 50,50 -10)'));
--- #690 --
-SELECT '#690';
-SELECT encode(ST_AsEWKB(ST_MakeLine(ST_GeomFromText('POINT(-11.1111111 40)'), ST_GeomFromText('LINESTRING(-11.1111111 70,70 -11.1111111)')),'ndr'),'hex') As result;
--- #693 --
-SELECT '#693a', ST_AsText(ST_GeomFromEWKT('SRID=4326;POLYGONM((-71.1319 42.2503 1,-71.132 42.2502 3,-71.1323 42.2504 -2,-71.1322 42.2505 1,-71.1319 42.2503 0))'));
-SELECT '#693b', ST_AsText(ST_GeomFromEWKT('SRID=4326;POLYGONM((-71.1319 42.2512 0,-71.1318 42.2511 20,-71.1317 42.2511 -20,-71.1317 42.251 5,-71.1317 42.2509 4,-71.132 42.2511 6,-71.1319 42.2512 30))'));
--- #694 --
-SELECT '#694';
-SELECT ST_MakePolygon('POINT(1 2)'::geometry);
--- #695 --
-SELECT '#695';
-SELECT ST_RemovePoint('POINT(-11.1111111 40)'::geometry, 1);
--- #696 --
-SELECT '#696',St_AsText(ST_Segmentize(ST_GeomFromEWKT('PolyhedralSurface( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)), ((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)), ((0 0 0, 1 0 0, 1 0 1, 0 0 1, 0 0 0)), ((1 1 0, 1 1 1, 1 0 1, 1 0 0, 1 1 0)), ((0 1 0, 0 1 1, 1 1 1, 1 1 0, 0 1 0)), ((0 0 1, 1 0 1, 1 1 1, 0 1 1, 0 0 1)) )'), 0.5));
--- #720 --
-SELECT '#720', ST_AsText(ST_SnapTogrid(ST_Transform(ST_GeomFromText('MULTIPOINT(-10 40,-10 55,-10 70,5 40,5 55,5 70,20 40,20 55,20 70,35 40,35 55,35 70,50 40,50 55,50 70)',4326), 3395), 0.01));
--- #723 --
-SELECT '#723',
- ST_AsText(ST_SnapToGrid( ST_Intersection(a.geog, b.geog)::geometry, 0.00001))
-FROM (VALUES (ST_GeogFromText('SRID=4326;POINT(-11.1111111 40)') ), (ST_GeogFromText('SRID=4326;POINT(-11.1111111 55)') ) ) As  a(geog) CROSS JOIN ( VALUES (ST_GeogFromText('SRID=4326;POINT(-11.1111111 40)') ), (ST_GeogFromText('SRID=4326;POINT(-11.1111111 55)') )) As b(geog);
--- #729 --
---SELECT '#729',ST_MakeLine(foo1.the_geom) As result FROM ((SELECT ST_GeomFromText('POINT EMPTY',4326) As the_geom UNION ALL SELECT ST_GeomFromText('MULTIPOINT EMPTY',4326) As the_geom UNION ALL SELECT ST_GeomFromText('MULTIPOLYGON EMPTY',4326) As the_geom UNION ALL SELECT ST_GeomFromText('LINESTRING EMPTY',4326) As the_geom UNION ALL SELECT ST_GeomFromText('MULTILINESTRING EMPTY',4326) As the_geom ) ) As foo1;
--- #804
-SELECT '#804', ST_AsGML(3, 'SRID=4326;POINT(0 0)'::geometry, 0, 1);
--- #845
-SELECT '#845', ST_Intersects('POINT(169.69960846592 -46.5061209281002)'::geometry, 'POLYGON((169.699607857174 -46.5061218662,169.699607857174 -46.5061195965597,169.699608806526 -46.5061195965597,169.699608806526 -46.5061218662,169.699607857174 -46.5061218662))'::geometry);
--- #834
-SELECT '#834', ST_AsEWKT(ST_Intersection('LINESTRING(0 0,0 10,10 10,10 0)', 'LINESTRING(10 10 4,10 0 5,0 0 5)'));
--- #884 --
-CREATE TABLE foo (id integer, the_geom geometry);
-INSERT INTO foo VALUES (1, st_geomfromtext('MULTIPOLYGON(((-113.6 35.4,-113.6 35.8,-113.2 35.8,-113.2 35.4,-113.6 35.4),(-113.5 35.5,-113.3 35.5,-113.3 35.7,-113.5 35.7,-113.5 35.5)))'));
-INSERT INTO foo VALUES (2, st_geomfromtext('MULTIPOLYGON(((-113.7 35.3,-113.7 35.9,-113.1 35.9,-113.1 35.3,-113.7 35.3),(-113.6 35.4,-113.2 35.4,-113.2 35.8,-113.6 35.8,-113.6 35.4)),((-113.5 35.5,-113.5 35.7,-113.3 35.7,-113.3 35.5,-113.5 35.5)))'));
-select '#884', id, ST_Within(
-ST_GeomFromText('POINT (-113.4 35.6)'), the_geom
-) from foo;
-select '#938', 'POLYGON EMPTY'::geometry::box2d;
-DROP TABLE foo;
--- #668 --
-select '#668',box2d('CIRCULARSTRING(10 2,12 2,14 2)'::geometry) as b;
--- #711 --
-select '#711', ST_GeoHash(ST_GeomFromText('POLYGON EMPTY',4326));
--- #712 --
-SELECT '#712',ST_IsValid(ST_GeomFromText('POLYGON EMPTY',4326));
--- #756
-WITH inp AS ( SELECT 'LINESTRING(0 0, 1 1)'::geometry as s,
-                     'LINESTRING EMPTY'::geometry as e      )
- SELECT '#756.1', ST_Equals(s, st_multi(s)),
-                  ST_Equals(s, st_collect(s, e))
- FROM inp;
--- #1023 --
-select '#1023', 'POINT(10 4)'::geometry = 'POINT(10 4)'::geometry;
-select '#1023.a', 'POINT(10 4)'::geometry = 'POINT(10 5)'::geometry;
-select '#1023.b', postgis_addbbox('POINT(10 4)'::geometry) = 'POINT(10 4)'::geometry;
--- #1069 --
-select '#1060', ST_Relate(ST_GeomFromText('POINT EMPTY',4326), ST_GeomFromText('POINT EMPTY',4326)) As result;
--- #1273 --
-WITH p AS ( SELECT 'POINT(832694.188 816254.625)'::geometry as g )
-SELECT '#1273', st_equals(p.g, postgis_addbbox(p.g)) from p;
--- Another for #1273 --
-WITH p AS ( SELECT 'MULTIPOINT((832694.188 816254.625))'::geometry as g )
-SELECT '#1273.1', st_equals(p.g, postgis_dropbbox(p.g)) from p;
--- #877, #818
-create table t(g geometry);
-select '#877.1', ST_EstimatedExtent('t','g');
-analyze t;
-select '#877.2', ST_EstimatedExtent('public', 't','g');
-select '#877.2.deprecated', ST_Estimated_Extent('public', 't','g');
-insert into t(g) values ('LINESTRING(-10 -50, 20 30)');
--- #877.3
-with e as ( select ST_EstimatedExtent('t','g') as e )
-select '#877.3', round(st_xmin(e.e)::numeric, 5), round(st_xmax(e.e)::numeric, 5),
-round(st_ymin(e.e)::numeric, 5), round(st_ymax(e.e)::numeric, 5) from e;
--- #877.4
-analyze t;
-select '#877.4', round(st_xmin(e.e)::numeric, 5), round(st_xmax(e.e)::numeric, 5),
--- #877.5
-truncate t;
-select '#877.5', round(st_xmin(e.e)::numeric, 5), round(st_xmax(e.e)::numeric, 5),
-drop table t;
--- #1292
-SELECT '#1292', ST_AsText(ST_SnapToGrid(ST_GeomFromText(
-	'GEOMETRYCOLLECTION(POINT(180 90),POLYGON((140 50,150 50,180 50,140 50),(140 60,150 60,180 60,140 60)))'
-	, 4326), 0.00001)::geography);
--- #1292.1
-SELECT '#1292.1', ST_AsText(ST_GeomFromText('POINT(180.00000000001 95)')::geography),
-	ST_AsText(ST_GeomFromText('POINT(185 90.00000000001)')::geography);
--- #1320
-SELECT '<#1320>';
-CREATE TABLE A ( geom geometry(MultiPolygon, 4326),
-                 geog geography(MultiPolygon, 4326) );
--- Valid inserts
-INSERT INTO a(geog) VALUES('SRID=4326;MULTIPOLYGON (((0 0, 10 0, 10 10, 0 0)))'::geography);
-INSERT INTO a(geom) VALUES('SRID=4326;MULTIPOLYGON (((0 0, 10 0, 10 10, 0 0)))'::geometry);
-SELECT '#1320.geog.1', geometrytype(geog::geometry), st_srid(geog::geometry) FROM a where geog is not null;
-SELECT '#1320.geom.1', geometrytype(geom), st_srid(geom) FROM a where geom is not null;
--- Type mismatches is not allowed
-INSERT INTO a(geog) VALUES('SRID=4326;POLYGON ((0 0, 10 0, 10 10, 0 0))'::geography);
-INSERT INTO a(geom) VALUES('SRID=4326;POLYGON ((0 0, 10 0, 10 10, 0 0))'::geometry);
-SELECT '#1320.geog.2', geometrytype(geog::geometry), st_srid(geog::geometry) FROM a where geog is not null;
-SELECT '#1320.geom.2', geometrytype(geom), st_srid(geom) FROM a where geom is not null;
--- Even if it's a trigger changing the type
-CREATE OR REPLACE FUNCTION triga() RETURNS trigger AS
-$$ BEGIN
-	NEW.geom = ST_GeometryN(New.geom,1);
-	NEW.geog = ST_GeometryN(New.geog::geometry,1)::geography;
-	RETURN NEW;
-END; $$ language plpgsql VOLATILE;
-CREATE TRIGGER triga_before
-  BEFORE INSERT ON a FOR EACH ROW
-  EXECUTE PROCEDURE triga();
-SELECT '#1320.geog.3', geometrytype(geog::geometry), st_srid(geog::geometry) FROM a where geog is not null;
-SELECT '#1320.geom.3', geometrytype(geom), st_srid(geom) FROM a where geom is not null;
-DROP TABLE A;
-DROP FUNCTION triga();
-SELECT '</#1320>';
--- st_AsText POLYGON((0 0,10 0,10 10,0 0))
--- #1344
-select '#1344', octet_length(ST_AsEWKB(st_makeline(g))) FROM ( values ('POINT(0 0)'::geometry ) ) as foo(g);
--- #1385
-SELECT '#1385', ST_Extent(g) FROM ( select null::geometry as g ) as foo;
--- #657
-SELECT '#657.1',Round(ST_X(ST_Project('POINT(175 10)'::geography, 2000000, 3.1415/2)::GEOMETRY)::numeric,2);
-SELECT '#657.2',Round(ST_Distance(ST_Project('POINT(10 10)'::geography, 10, 0), 'POINT(10 10)'::geography)::numeric,2);
-SELECT '#657.3',ST_DWithin(ST_Project('POINT(10 10)'::geography, 2000, pi()/2), 'POINT(10 10)'::geography, 2000);
--- #1305
-SELECT '#1305.1',ST_AsText(ST_Project('POINT(10 10)'::geography, 0, 0));
-WITH pts AS ( SELECT 'POINT(0 45)'::geography AS s, 'POINT(45 45)'::geography AS e )
-SELECT '#1305.2',abs(ST_Distance(e, ST_Project(s, ST_Distance(s, e), ST_Azimuth(s, e)))) < 0.001 FROM pts;
-SELECT '#1305.3',ST_Azimuth('POINT(0 45)'::geography, 'POINT(0 45)'::geography) IS NULL;
--- #1445
-SELECT '01060000400200000001040000400100000001010000400000000000000000000000000000000000000000000000000101000040000000000000F03F000000000000F03F000000000000F03F'::geometry;
-SELECT '01050000400200000001040000400100000001010000400000000000000000000000000000000000000000000000000101000040000000000000F03F000000000000F03F000000000000F03F'::geometry;
-SELECT '01040000400200000001040000400100000001010000400000000000000000000000000000000000000000000000000101000040000000000000F03F000000000000F03F000000000000F03F'::geometry;
-SELECT '01090000400200000001040000400100000001010000400000000000000000000000000000000000000000000000000101000040000000000000F03F000000000000F03F000000000000F03F'::geometry;
-SELECT '010B0000400200000001040000400100000001010000400000000000000000000000000000000000000000000000000101000040000000000000F03F000000000000F03F000000000000F03F'::geometry;
-SELECT '010C0000400200000001040000400100000001010000400000000000000000000000000000000000000000000000000101000040000000000000F03F000000000000F03F000000000000F03F'::geometry;
--- #1453
-SELECT '#1453.1', ST_OrderingEquals('POINT EMPTY', 'POINT EMPTY');
-SELECT '#1453.2', ST_OrderingEquals('POINT EMPTY', 'POINT Z EMPTY');
--- #1454
-with inp as ( select 'MULTILINESTRING((0 0, 2 0))'::geometry as g )
-SELECT '#1454', st_orderingequals(g,g) from inp;
--- #1414
-SELECT '#1414', st_astext(st_Force3DZ('CURVEPOLYGON EMPTY'));
--- #1478
-SELECT '#1478', ST_AsText('SRID=1;POINT EMPTY'::geometry::text::geometry);
--- #745
-SELECT '#745', ST_AsEWKT(ST_Split('POLYGON((-72 42 1,-70 43 1,-71 41 1,-72 42 1))',
-                                  'LINESTRING(-10 40 1,-9 41 1)'));
--- #1450
-SELECT '#1450', GeometryType('POINT(0 0)'::geography), GeometryType('POLYGON EMPTY'::geography);
--- #1482
-select '#1482', ST_Srid('POINT(0 0)'::geography(point, 0)::geometry);
--- #852
-CREATE TABLE cacheable (id int, g geometry);
-COPY cacheable FROM STDIN;
-1	POINT(0.5 0.5000000000001)
-2	POINT(0.5 0.5000000000001)
-select '#852.1', id, -- first run is not cached, consequent are cached
-  st_intersects(g, 'POLYGON((0 0, 10 10, 1 0, 0 0))'::geometry),
-  st_intersects(g, 'POLYGON((0 0, 1 1, 1 0, 0 0))'::geometry) from cacheable;
-UPDATE cacheable SET g = 'POINT(0.5 0.5)';
--- New select, new cache
-select '#852.2', id, -- first run is not cached, consequent are cached
-DROP TABLE cacheable;
--- #1489
-with inp AS ( SELECT
-	st_multi('POINT EMPTY'::geometry) as mp,
-	st_multi('LINESTRING EMPTY'::geometry) as ml,
-	st_multi('POLYGON EMPTY'::geometry) as ma,
-	st_multi('GEOMETRYCOLLECTION EMPTY'::geometry) as mm
-) select '#1489',
-	st_astext(mp), st_numgeometries(mp),
-	st_astext(ml), st_numgeometries(ml),
-	st_astext(ma), st_numgeometries(ma),
-	st_astext(mm), st_numgeometries(mm)
-FROM inp;
--- #1150
-insert into spatial_ref_sys (srid, proj4text) values (500001,NULL);
-insert into spatial_ref_sys (srid, proj4text) values (500002, '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs');
-select '#1150', st_astext(st_transform('SRID=500002;POINT(0 0)'::geometry,500001));
--- #1038
-select '#1038', ST_AsSVG('POLYGON EMPTY'::geometry);
--- #1042
-select '#1042',round((st_ymax(st_minimumboundingcircle('LINESTRING(-1 -1, 1 1)')) * st_xmax(st_minimumboundingcircle('LINESTRING(-1 -1, 1 1)')))::numeric,0);
--- #1170 --
-SELECT '#1170', ST_Y(ST_Intersection( ST_GeogFromText( 'POINT(0 90)'), ST_GeogFromText( 'POINT(0 90)' ))::geometry);
--- #1264 --
-SELECT '#1264', ST_DWithin('POLYGON((-10 -10, -10 10, 10 10, 10 -10, -10 -10))'::geography, 'POINT(0 0)'::geography, 0);
--- #1398
-select '#1398a', st_astext(st_snaptogrid(st_project('POINT(-120 45)'::geography, 100000, radians(45))::geometry,0.000001));
-select '#1398b', st_astext(st_snaptogrid(st_project('POINT(20 85)'::geography, 2000000, radians(0.1))::geometry,0.000001));
--- #1543
-'0105000000020000000102000000040000000000000000000000000000000000000000000000000024400000000000000000000000000000244000000000000024400000000000000000000000000000000001020000000100000000000000000000000000000000000000'
-::geometry as g )
-select '#1543', st_astext(g), st_astext(st_buildarea(g)) from inp;
--- #1580
-select '#1580.1', ST_Summary(ST_Transform('SRID=4326;POINT(0 0)'::geometry, 3395));
-select '#1580.2', ST_Transform('SRID=4326;POINT(180 90)'::geometry, 3395); -- fails
-select '#1580.3', ST_Summary(ST_Transform('SRID=4326;POINT(0 0)'::geometry, 3395));
--- #1596 --
-SELECT '#1596.1', AddGeometryColumn( 'road_pg','roads_geom', 3395, 'POINT', 2 );
-SELECT '#1596.2', UpdateGeometrySRID( 'road_pg','roads_geom', 330000);
-SELECT '#1596.3', srid FROM geometry_columns
-  WHERE f_table_name = 'road_pg' AND f_geometry_column = 'roads_geom';
-SELECT '#1596.4', UpdateGeometrySRID( 'road_pg','roads_geom', 999000);
-SELECT '#1596.5', srid FROM geometry_columns
-SELECT '#1596.6', UpdateGeometrySRID( 'road_pg','roads_geom', -1);
-SELECT '#1596.7', srid FROM geometry_columns
--- #1596
- 'POLYGON((-176 -22,-176 -21,-175 -21,-175 -22,-176 -22))'::geography as a,
- 'POINT(-176 -22)'::geography as p
-) SELECT '#1596', ST_Summary(ST_Intersection(a,p)) FROM inp;
--- #1695
-SELECT '#1695', ST_AsEWKT(ST_SnapToGrid('MULTIPOLYGON(((0 0, 10 0, 10 10, 0 10, 0 0)))'::geometry, 20));
--- #1697 --
-CREATE TABLE eg(g geography, gm geometry);
-CREATE INDEX egi on eg using gist (g);
-CREATE INDEX egind on eg using gist (gm gist_geometry_ops_nd);
-INSERT INTO eg (g, gm)
- select 'POINT EMPTY'::geography,
-        'POINT EMPTY'::geometry
- from generate_series(1,1024);
-SELECT '#1697.1', count(*) FROM eg WHERE g && 'POINT(0 0)'::geography;
-SELECT '#1697.2', count(*) FROM eg WHERE gm && 'POINT(0 0)'::geometry;
-SELECT '#1697.3', count(*) FROM eg WHERE gm ~= 'POINT EMPTY'::geometry;
-DROP TABLE eg;
--- #1734 --
-create table eg (g geography);
-create index egi on eg using gist (g);
-INSERT INTO eg(g) VALUES (NULL);
-INSERT INTO eg (g) VALUES ('POINT(0 0)'::geography);
-INSERT INTO eg (g) select 'POINT(0 0)'::geography
-       FROM generate_series(1,1024);
-SELECT '#1734.1', count(*) FROM eg;
-DROP table eg;
--- #1755 --
-select '#1755', ST_AsText(st_geographyFromText('SRID=4326;Point(85 35 0)'));
--- #1776 --
-with inp as ( SELECT
- 'POLYGON EMPTY'::geometry as A,
- 'POLYGON((0 0, 10 0, 10 10, 0 0))'::geometry as B )
-SELECT '#1776',
- ST_AsText(ST_SymDifference(A,B)), ST_AsText(ST_SymDifference(B, A))
-FROM inp;
--- #1780 --
-SELECT '#1780',ST_GeoHash('POINT(4 4)'::geometry) = ST_GeoHash('POINT(4 4)'::geography);
--- #1791 --
- '010100000000000000004065C0041AD965BE5554C0'::geometry as a,
- '010100000001000000004065C0041AD965BE5554C0'::geometry as b
-) SELECT '#1791', round(ST_Azimuth(a,b)*10)/10 from inp;
--- #1799 --
-SELECT '#1799', ST_Segmentize('LINESTRING(0 0, 10 0)'::geometry, 0);
--- #1936 --
-select st_astext(st_geomfromgml(
-    '<gml:Polygon xmlns:gml="http://www.opengis.net/gml/3.2"
-    gml:id="HPA.15449990010" srsName="urn:ogc:def:crs:EPSG::4326"
-    srsDimension="2">
-    <gml:exterior>
-    <gml:Ring>
-    <gml:curveMember>
-    <gml:LineString gml:id="HPA.15449990010.1">
-    <gml:posList>711540.35 1070163.61 711523.82 1070166.54 711521.30 1070164.14 711519.52 1070162.44 711518.57 1070164.62 712154.47 1070824.94</gml:posList>
-    </gml:LineString>
-    </gml:curveMember>
-    <gml:curveMember>
-    <gml:Curve gml:id="HPA.15449990010.2">
-    <gml:segments><gml:ArcString>
-    <gml:posList>712154.47 1070824.94 712154.98 1070826.04 712154.41 1070827.22</gml:posList>
-    </gml:ArcString>
-    </gml:segments>
-    </gml:Curve>
-    <gml:curveMember>
-    <gml:LineString gml:id="HPA.15449990010.3">
-    <gml:posList>712154.41 1070827.22 712160.31 1070837.07 712160.92 1070835.36 712207.89 1071007.95</gml:posList>
-    </gml:LineString>
-    <gml:curveMember>
-    <gml:Curve gml:id="HPA.15449990010.4"><gml:segments><gml:ArcString><gml:posList>712207.89 1071007.95 712207.48 1071005.59 712208.38 1071001.28</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember><gml:curveMember><gml:LineString gml:id="HPA.15449990010.5"><gml:posList>712208.38 1071001.28 712228.74 1070949.67 712233.98 1070936.15 712124.93 1070788.72</gml:posList></gml:LineString></gml:curveMember><gml:curveMember><gml:Curve gml:id="HPA.15449990010.6"><gml:segments><gml:ArcString><gml:posList>712124.93 1070788.72 712124.28 1070785.87 712124.63 1070783.38</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember><gml:curveMember><gml:LineString gml:id="HPA.15449990010.7"><gml:posList>712124.63 1070783.38 712141.04 1070764.12 712146.60 1070757.01 711540.35 1070163.61</gml:posList></gml:LineString></gml:curveMember></gml:Ring></gml:exterior>
-    <gml:interior>
-    <gml:LinearRing>
-    <gml:posList>713061.62 1070354.46 713053.59 1070335.12 713049.58 1070315.92 713049.65 1070298.33 713061.62 1070354.46</gml:posList>
-    </gml:LinearRing>
-    </gml:interior>
-    </gml:Polygon>'));
--- #1978 --
-SELECT '#1978', round(ST_Length(ST_GeomFromText('CIRCULARSTRING(0 0,1 0,0 0)',0))::numeric,4);
--- #1996 --
-SELECT '#1996', ST_AsGeoJSON(ST_GeomFromText('POINT EMPTY'));
--- #2001 --
-SELECT '#2001', ST_AsText(ST_CurveToLine(ST_GeomFromText('CURVEPOLYGON((0 0, 0 1, 1 1, 0 0))'), 2));
--- #2028 --
-SELECT '#2028', ST_AsText(ST_Multi('TRIANGLE((0 0, 0 1, 1 1, 0 0))'));
--- #2035 START ------------------------------------------------------------
--- Simple geographic table, with single point.
-CREATE TABLE "city" (
-    "id" integer,
-    "name" varchar(30) NOT NULL,
-    "point" geometry(POINT,4326) NOT NULL
-CREATE INDEX "city_point_id" ON "city" USING GIST ( "point" );
--- Initial data, with points around the world.
-INSERT INTO "city" (id, name, point) VALUES (1, 'Houston', 'SRID=4326;POINT(-95.363151 29.763374)');
-INSERT INTO "city" (id, name, point) VALUES (2, 'Dallas', 'SRID=4326;POINT(-95.363151 29.763374)');
-INSERT INTO "city" (id, name, point) VALUES (3, 'Oklahoma City', 'SRID=4326;POINT(-97.521157 34.464642)');
-INSERT INTO "city" (id, name, point) VALUES (4, 'Wellington', 'SRID=4326;POINT(174.783117 -41.315268)');
-INSERT INTO "city" (id, name, point) VALUES (5, 'Pueblo', 'SRID=4326;POINT(-104.609252 38.255001)');
-INSERT INTO "city" (id, name, point) VALUES (6, 'Lawrence', 'SRID=4326;POINT(-95.23506 38.971823)');
-INSERT INTO "city" (id, name, point) VALUES (7, 'Chicago', 'SRID=4326;POINT(-87.650175 41.850385)');
-INSERT INTO "city" (id, name, point) VALUES (8, 'Victoria', 'SRID=4326;POINT(-123.305196 48.462611)');
--- This query, or COUNT(*), does not return anything; should return 6 cities,
--- excluding Pueblo and Victoria.  The Polygon is a simple approximation of
--- Colorado.
-SELECT '#2035a', Count(*) FROM "city"
-  WHERE "city"."point" >> ST_GeomFromEWKT('SRID=4326;POLYGON ((-109.060253 36.992426, -109.060253 41.003444, -102.041524 41.003444, -102.041524 36.992426, -109.060253 36.992426))');
--- However, when a LIMIT is placed on statement, the query suddenly works.
-SELECT '#2035b', Count(*) FROM "city"
-  WHERE "city"."point" >> ST_GeomFromEWKT('SRID=4326;POLYGON ((-109.060253 36.992426, -109.060253 41.003444, -102.041524 41.003444, -102.041524 36.992426, -109.060253 36.992426))') LIMIT 6;
-DROP TABLE "city";
--- #2035 END --------------------------------------------------------------
--- #2084 --
-SELECT '#2048', num, ST_Within('POINT(-54.394 56.522)', "the_geom"), ST_CoveredBy('POINT(-54.394 56.522)', "the_geom")
-FROM ( VALUES
-(1, '0103000000010000000E00000051C6F7C5A5324BC02EB69F8CF13F4C40F12EA4C343364BC0326AA2CF47434C402BC1A8A44E364BC02A50E10852434C407F2990D959364BC0A0D1730B5D434C404102452C62364BC0ECF335CB65434C400903232F6B364BC0F635E84B6F434C40BD0CC51D6F364BC0D2805EB873434C40B9E6E26F7B364BC0F20B93A982434C40D9FAAF73D3344BC0FE84D04197444C40BD5C8AABCA344BC0CED05CA791444C4023F2237EC5344BC02A84F23E8E444C40BDCDD8077B324BC0C60FB90F01434C409FD1702E65324BC04EF1915C17404C4051C6F7C5A5324BC02EB69F8CF13F4C40'::geometry),
-(2, '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'::geometry),
-(3, '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'::geometry)
-) AS f(num, the_geom);
--- #2112 -- Start
-SELECT '#2112a', ST_3DDistance(a,b), ST_ASEWKT(ST_3DShortestLine(a,b))
-FROM (SELECT 'POLYGON((1 1 1, 5 1 1,5 5 1, 1 5 1,1 1 1))'::geometry as a, 'LINESTRING(0 0 2, 0 0 0,5 5 2)'::geometry as b
-     ) as foo;
-SELECT '#2112b', ST_3DDistance(a,b), ST_ASEWKT(ST_3DShortestLine(a,b))
-FROM (SELECT 'POLYGON((1 1 1, 5 1 1,5 5 1, 1 5 1,1 1 1))'::geometry as a, 'LINESTRING(1 0 2, 1 0 0,5 5 -1)'::geometry as b
-     ) as foo;
--- 2112 -- End
-SELECT '#2108', ST_AsEWKT(ST_LineInterpolatePoint('SRID=3395;LINESTRING M EMPTY'::geometry, 0.5));
-SELECT '#2117', ST_AsEWKT(ST_PointOnSurface('SRID=3395;MULTIPOLYGON M EMPTY'::geometry));
-SELECT '#2110.1', 'POINT(0 0)'::geometry = 'POINT EMPTY'::geometry;
-SELECT '#2110.2', 'POINT EMPTY'::geometry = 'POINT EMPTY'::geometry;
-SELECT '#2110.3', 'POINT(0 0)'::geometry = 'POINT(0 0)'::geometry;
-SELECT '#2145',
-round(ST_Length(St_Segmentize(ST_GeographyFromText('LINESTRING(-89.3000030518 28.2000007629,-89.1999969482 89.1999969482,-89.1999969482 89.1999969482)'), 10000))::numeric,0);
-SELECT '#3255';
--- should raise an error
-SELECT ST_3DDifference('POINT(-11 40)'::geometry, 'POLYGON((1 2,1 2,1 2,1 2))'::geometry);
--- Clean up
Deleted: trunk/regress/sfcgal/tickets_expected
--- trunk/regress/sfcgal/tickets_expected	2018-12-04 19:39:28 UTC (rev 17100)
+++ trunk/regress/sfcgal/tickets_expected	2018-12-04 20:03:09 UTC (rev 17101)
@@ -1,252 +0,0 @@
-#2|POLYGON((1 1,1 2,2 2,3 2,3 1,2 1,1 1))
-#11|0
-WARNING:  ST_Locate_Between_Measures and ST_Locate_Along_Measure were deprecated in 2.2.0. Please use ST_LocateAlong and ST_LocateBetween
-#21|SRID=31293;POINTM(6220.13 5337367.145 4566)
-t
-ERROR:  AddGeometryColumn() - invalid SRID
-#44|t|t
-#58|220187|150406|220289|150507
-ERROR:  lwgeom_to_gml2: 'CurvePolygon' geometry type not supported
-#66|CIRCULARSTRING(0 0,1 1,2 2)
-#68a|MULTIPOINT(1 3,4 5)
-ERROR:  lwgeom_longitude_shift: unsupported geom type: CircularString
-#69|CIRCULARSTRING(220269 150417,220228 150507,220228 150408)
-#70|3
-#73|GEOMETRYCOLLECTION(CIRCULARSTRING(1 1,2 3,4 5,6 7,5 6))
-#80|MULTILINESTRING((0 0,1 1))
-#83|MULTICURVE(CIRCULARSTRING(220268 150415,220227 150505,220227 150406))
-#85|0
-#112|GEOMETRYCOLLECTION(POINT(-10 50))
-ERROR:  Geometry argument does not have an 'M' ordinate
-#116|POLYGON EMPTY
-#122|CIRCULARSTRING(220268 150415,220227 150505,220227 150406)
-#124a|COMPOUNDCURVE(CIRCULARSTRING(0 0,1 1,1 0),(1 0,30 5),CIRCULARSTRING(30 5,34 56,67 89))
-ERROR:  incontinuous compound curve
-#145a|POLYGON EMPTY
-#145b|0
-#146|0|t|GEOMETRYCOLLECTION(LINESTRING(0 0,-1 -1),MULTIPOINT(1 2,2 3))
-ERROR:  Invalid hex string, length (267) has to be a multiple of two!
-#157|ST_Polygon|POLYGON
-#157|ST_Point|POINT
-#157|ST_CurvePolygon|CURVEPOLYGON
-#157|ST_CircularString|CIRCULARSTRING
-#168|3|MULTIPOLYGON ZM (((4275341.96977851 259186.966993061 1323.76295828331 -1.79769e+308,4275341.96977851 259186.966993061 1323.76295828331 -1.79769e+308,4275341.96977851 259186.966993061 1323.76295828331 -1.79769e+308)))|IllegalArgumentException: Invalid number of points in LinearRing found 3 - must be 0 or >= 4
-#175|SRID=26915;POINT(482020 4984378)
-#178a|0
-#178b|5
-NOTICE:  No points or linestrings in input array
-#179a|
-#179b|
-#183|COMPOUNDCURVE(CIRCULARSTRING(0 0,0.5 1.2071067812,1 0),(1 0,0 1))
-#210a|
-#210b|
-#213|17
-#234|COMPOUNDCURVE((0 0,1 1))
-#241|0
-#254|GEOMETRYCOLLECTION EMPTY
-#259|
-#260|1667701
-#261|0
-#262|POINT(-119.5434 34.9438)|t|t|t
-#262|POINT(-119.5452 34.9442)|t|t|t
-#262|POINT(-119.5438 34.9443)|t|t|t
-#263|SRID=4326;POINT(-119.5434 34.9438)|t|t|t
-#263|SRID=4326;POINT(-119.5452 34.9442)|t|t|t
-#263|SRID=4326;POINT(-119.5438 34.9443)|t|t|t
-#271|t
-#272|-2|2
-#277|<gml:Point><gml:coordinates>1,1e+308</gml:coordinates></gml:Point>
-#299|2
-#304
-#304.a|21
-#304.b|1
-#408|Too few points in geometry component[
-NOTICE:  Too few points in geometry component at or near point 0 0
-#408.1|f
-#408.2|Too few points in geometry component[0 0]
-NOTICE:  IllegalArgumentException: Invalid number of points in LinearRing found 2 - must be 0 or >= 4
-#408.3|f
-#408.4|IllegalArgumentException: Invalid number of points in LinearRing found 2 - must be 0 or >= 4
-#457.1|POINT(0 0)
-#457.2|LINESTRING EMPTY
-#457.3|POLYGON EMPTY
-#457.4|POINT EMPTY
-#457.5|LINESTRING(0 0,1 1)
-#457.6|POLYGON EMPTY
-#457.7|POINT EMPTY
-#457.8|LINESTRING EMPTY
-#457.9|POLYGON((0 0,1 0,1 1,0 1,0 0))
-#835.1|POINT EMPTY
-#835.2|LINESTRING EMPTY
-#835.3|POLYGON EMPTY
-#835.4|POINT EMPTY
-#835.5|LINESTRING EMPTY
-#835.6|POLYGON EMPTY
-#835.7|POINT EMPTY
-#835.8|LINESTRING EMPTY
-#835.9|POLYGON EMPTY
-#835.10|MULTIPOINT EMPTY
-#835.11|MULTILINESTRING EMPTY
-#835.12|MULTIPOLYGON EMPTY
-#650|MULTIPOINT(0 0,1 1,2 2)
-#667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 39.9999999999999,30 40))
-#677|1121395
-#680|01d107000000000000000024c000000000000049400000000000000040
-#681a|
-#681b|
-#681c|
-#681d|
-#681e|
-#681f|
-#681g|
-#682|POLYGON EMPTY
-#683|POLYGON EMPTY
-#684,#2109|SRID=4326;POINT EMPTY
-#2109|SRID=3395;POINT EMPTY
-#685|POLYGON EMPTY
-#686|GEOMETRYCOLLECTION(POLYGON EMPTY,TRIANGLE EMPTY)
-#687|f
-#689|f
-#690
-010200000003000000f771d98de33826c00000000000004440f771d98de33826c000000000008051400000000000805140f771d98de33826c0
-#693a|POLYGON M ((-71.1319 42.2503 1,-71.132 42.2502 3,-71.1323 42.2504 -2,-71.1322 42.2505 1,-71.1319 42.2503 0))
-#693b|POLYGON M ((-71.1319 42.2512 0,-71.1318 42.2511 20,-71.1317 42.2511 -20,-71.1317 42.251 5,-71.1317 42.2509 4,-71.132 42.2511 6,-71.1319 42.2512 30))
-#694
-ERROR:  Shell is not a line
-#695
-ERROR:  First argument must be a LINESTRING
-#696|POLYHEDRALSURFACE Z (((0 0 0,0 0 1,0 1 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,1 0 1,0 0 1,0 0 0)),((1 1 0,1 1 1,1 0 1,1 0 0,1 1 0)),((0 1 0,0 1 1,1 1 1,1 1 0,0 1 0)),((0 0 1,1 0 1,1 1 1,0 1 1,0 0 1)))
-#720|MULTIPOINT(-1113194.91 4838471.4,-1113194.91 7326837.72,-1113194.91 11028513.63,556597.45 4838471.4,556597.45 7326837.72,556597.45 11028513.63,2226389.82 4838471.4,2226389.82 7326837.72,2226389.82 11028513.63,3896182.18 4838471.4,3896182.18 7326837.72,3896182.18 11028513.63,5565974.54 4838471.4,5565974.54 7326837.72,5565974.54 11028513.63)
-#723|POINT(-11.11111 40)
-#723|GEOMETRYCOLLECTION EMPTY
-#723|POINT(-11.11111 55)
-#804|<gml:Point srsName="urn:ogc:def:crs:EPSG::4326"><gml:pos srsDimension="2">0 0</gml:pos></gml:Point>
-#845|t
-#834|GEOMETRYCOLLECTION(POINT(0 0 5),LINESTRING(10 10 5,10 0 5))
-#884|1|f
-#884|2|t
-#938|
-#668|BOX(10 2,14 2)
-#711|
-#712|t
-#756.1|t|t
-#1023|t
-#1023.a|f
-#1023.b|t
-#1060|FFFFFFFF2
-#1273|t
-#1273.1|t
-WARNING:  stats for "t.g" do not exist
-#877.1|
-#877.2|
-WARNING:  ST_Estimated_Extent signature was deprecated in 2.1.0. Please use ST_EstimatedExtent
-#877.2.deprecated|
-#877.3||||
-#877.4|-10.15000|20.15000|-50.40000|30.40000
-#877.5|-10.15000|20.15000|-50.40000|30.40000
-#1292|GEOMETRYCOLLECTION(POINT(180 90),POLYGON((140 50,150 50,180 50,140 50),(140 60,150 60,180 60,140 60)))
-NOTICE:  Coordinate values were coerced into range [-180 -90, 180 90] for GEOGRAPHY
-#1292.1|POINT(180 85)|POINT(-175 90)
-<#1320>
-#1320.geog.1|MULTIPOLYGON|4326
-#1320.geom.1|MULTIPOLYGON|4326
-ERROR:  Geometry type (Polygon) does not match column type (MultiPolygon)
-#1320.geog.2|MULTIPOLYGON|4326
-#1320.geom.2|MULTIPOLYGON|4326
-#1320.geog.3|MULTIPOLYGON|4326
-#1320.geom.3|MULTIPOLYGON|4326
-</#1320>
-#1344|25
-#1385|
-#657.1|-166.78
-#657.2|10.00
-#657.3|t
-#1305.1|POINT(10 10)
-#1305.2|t
-#1305.3|t
-ERROR:  MultiPolygon cannot contain MultiPoint element at character 8
-ERROR:  MultiLineString cannot contain MultiPoint element at character 8
-ERROR:  MultiPoint cannot contain MultiPoint element at character 8
-ERROR:  CompoundCurve cannot contain MultiPoint element at character 8
-ERROR:  MultiCurve cannot contain MultiPoint element at character 8
-ERROR:  MultiSurface cannot contain MultiPoint element at character 8
-#1453.1|t
-#1453.2|f
-#1454|t
-#1414|CURVEPOLYGON Z EMPTY
-#1478|POINT EMPTY
-#745|GEOMETRYCOLLECTION(POLYGON((-72 42 1,-70 43 1,-71 41 1,-72 42 1)))
-#1450|POINT|POLYGON
-#1482|4326
-#852.1|1|f|f
-#852.1|2|f|f
-#852.2|1|t|t
-#852.2|2|t|t
-#1489|MULTIPOINT EMPTY|0|MULTILINESTRING EMPTY|0|MULTIPOLYGON EMPTY|0|GEOMETRYCOLLECTION EMPTY|0
-ERROR:  AddToPROJ4SRSCache: could not parse proj4 string ''
-#1038|
-#1042|2
-#1170|90
-#1264|t
-#1398a|POINT(-119.093153 45.632669)
-#1398b|POINT(-160.137654 77.091608)
-#1543|MULTILINESTRING((0 0,10 0,10 10,0 0),(0 0))|POLYGON((0 0,10 10,10 0,0 0))
-#1580.1|Point[S]
-ERROR:  transform: couldn't project point (180 90 0): tolerance condition error (-20)
-#1580.3|Point[S]
-#1596.1|public.road_pg.roads_geom SRID:3395 TYPE:POINT DIMS:2
-ERROR:  invalid SRID: 330000 not found in spatial_ref_sys
-#1596.3|3395
-ERROR:  invalid SRID: 999000 not found in spatial_ref_sys
-#1596.5|3395
-NOTICE:  SRID value -1 converted to the officially unknown SRID value 0
-#1596.6|public.road_pg.roads_geom SRID changed to 0
-#1596.7|0
-#1596|Point[GS]
-#1695|MULTIPOLYGON EMPTY
-#1697.1|0
-#1697.2|0
-#1697.3|1024
-#1734.1|1026
-#1755|POINT Z (85 35 0)
-#1776|POLYGON((0 0,10 0,10 10,0 0))|POLYGON((0 0,10 0,10 10,0 0))
-#1780|t
-#1791|4.7
-ERROR:  ST_Segmentize: invalid max_distance 0 (must be >= 0)
-ERROR:  invalid GML representation
-#1978|3.1416
-#1996|{"type":"Point","coordinates":[]}
-#2001|POLYGON((0 0,0 1,1 1,0 0))
-#2028|TIN(((0 0,0 1,1 1,0 0)))
-#2035a|6
-#2035b|6
-#2048|1|f|f
-#2048|2|t|t
-#2048|3|f|f
-#2112a|0|LINESTRING(2.5 2.5 1,2.5 2.5 1)
-#2112b|1|LINESTRING(1 1 1,1 0 1)
-#2108|SRID=3395;POINTM EMPTY
-#2117|SRID=3395;POINTM EMPTY
-#2110.1|f
-#2110.2|t
-#2110.3|t
-#2145|6792004
-#3255
-NOTICE:  During difference_3d(A,B) :
-NOTICE:    with A: POINT(-11/1 40/1)
-NOTICE:     and B: POLYGON((1/1 2/1,1/1 2/1,1/1 2/1,1/1 2/1))
-ERROR:  When converting to 3D - Polygon is invalid : ring 0 degenerated to a point : POLYGON((1/1 2/1 0/1,1/1 2/1 0/1,1/1 2/1 0/1,1/1 2/1 0/1))
